A variable power sources (like solar panel) component in protein required
mugheesnawaz
Member level 1
variable power source (like solar panel) component in proteus required
i want library for a solar panel in proteus or a variable power supply which gives voltage and current variation during simulation.kindly help
Re: variable power source (like solar panel) component in proteus required
A PV panel puts out high A at low V, or low A at high V. It depends on how much you load it.
Example:
0.1 A @ 20V (2W, light load)
4 A @ 0.5 V (2W, heavy load)
Maximum power transfer is at a middle point. Example, 2A @ 12V (24W, medium load).
This is difficult behavior to model in a component. I have not seen a simple circuit which is able to mimic it.
Thanks for the reply,i thought there is some component for it just like i have downloaded microphone's library the other day.
i would be very thankful if you can find a variable power supply for proteus as the one attached (image) proteus_alps_blend.png
would appreciate any reply from others as well :)
To simulate a PV panel, I believe it's okay to use a DC source and a resistor in series.
The scope traces agree pretty much with real tests I did on my PV panels, by attaching different value resistors.
Notice you do not get maximum power at highest V or highest A.
Rather it occurs at a middle point. It is where the load equals the panel's internal resistance. This is the principle of impedance matching.
Thank you so much i am doing what you guided :)
