+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 1
    Points: 21, Level: 1
    Join Date
    Feb 2015
    0 / 0
    USART connection between two PIC18F Starter Kits
    I am new to PIC18 world and I have a big problem. I bought two PIC18F Stater Kits with PIC18F46J50 microcontroller, Oled display and card reader and I want to connect them using RS232. I already connect the two boards by soldering two wires on D2 and D3 pins.
    I've read that I need to use USART2, since USART1 is already connected to the card reader. So, I need to reprogram the pins RD2 and RD3 (RP20 and RP19). The problem is that I cannot find a single demo USART2 that is working. I want to send a string of characters from Board no1. to Board no2. using RS232, and eventually print the characters on the OLED.
    Here is a piece of code that I use to transmit the characters. I think it works, but i need another code for board no2, to see something (the receive part).
    #define _XTAL_FREQ 8000000 //The speed of your internal(or)external oscillator
    int i = 0;
     // CONFIG1L
    #pragma config WDTEN = OFF          // Watchdog Timer (Disabled - Controlled by SWDTEN bit)
    #pragma config PLLDIV =3            // PLL Prescaler Selection bits - Divide by 3 (12 MHz oscillator input)
    #pragma config STVREN = ON          // Stack Overflow/Underflow Reset  (Enabled)
    #pragma config XINST = OFF          // Extended instruction set disabled
    // CONFIG1H
    #pragma config CPUDIV = OSC1        // CPU System Clock Postscaler (No CPU system clock divide)
    #pragma config CP0 = OFF            // Code Protect (Program memory is not code-protected)
    // CONFIG2L
    #pragma config OSC = HSPLL          //HS oscillator, PLL enabled, HSPLL used by USB
    #pragma config T1DIG = ON           // T1OSCEN Enforcement (Secondary Oscillator clock source may be selected)
    #pragma config LPT1OSC = OFF        // Low-Power Timer1 Oscillator (High-power operation)
    #pragma config FCMEN = OFF          //Fail-Safe Clock Monitor disabled
    #pragma config IESO = OFF           //Two-Speed Start-up disabled
    // CONFIG2H
    #pragma config WDTPS = 32768        // Watchdog Postscaler (1:32768)
    // CONFIG3L
    #pragma config DSWDTOSC = INTOSCREF // DSWDT Clock Select (DSWDT uses INTRC)
    #pragma config RTCOSC = T1OSCREF    // RTCC Clock Select (RTCC uses T1OSC/T1CKI)
    #pragma config DSBOREN = OFF        // Zero-Power BOR disabled in Deep Sleep
    #pragma config DSWDTEN = OFF        // Deep Sleep Watchdog Timer (Disabled)
    #pragma config DSWDTPS = 8192       //1:8,192 (8.5 seconds)
    // CONFIG3H
    #pragma config IOL1WAY =OFF         //IOLOCK bit can be set and cleared
    #pragma config MSSP7B_EN = MSK7     // MSSP address masking (7 Bit address masking mode)
    // CONFIG4L
    #pragma config WPFP = PAGE_1        // Write/Erase Protect Page Start/End Location (Write Protect Program Flash Page 0)
    #pragma config WPEND = PAGE_0       //Start protection at page 0
    #pragma config WPCFG = OFF          //Write/Erase last page protect Disabled
    // CONFIG4H
    #pragma config WPDIS = OFF             //WPFP[5:0], WPEND, and WPCFG bits ignored
     #define USE_AND_MASKS
    unsigned char Txdata[] = "MICROCHIP_USART";
    void Delay1Second(void);
     void main (void)
         unsigned char config=0,spbrg=0,baudconfig=0,i=0;
    // //------PPS Configuration to map ESUART2 to correct pins ----
    // another reconfiguration of the pins
    //     PPSUnLock();
    //     // Configure RD3/RP20 as UART_TX
    //     iPPSOutput(OUT_PIN_PPS_RP20, OUT_FN_PPS_TX2CK2);
    //      // Configure RD2/RP19 as UART_RX
    //     iPPSInput(IN_FN_PPS_RX2DT2, IN_PIN_PPS_RP19);
    //     PPSLock();
         // REMAP ID PORT
        PPSCON = 0x00;              // unlock peripheral Pin select register
        RPOR19 = 0x05;              // assign USART2 TX to RP19/RD2
        RPINR16 = 0x14;             // assign USART2 RX to RP20/RD3
        PPSCON = 0x01;              // lock peripheral Pin select register
        TRISDbits.TRISD2 = 0;       // TX2 output
        TRISDbits.TRISD3 = 1;       // RX2 input
     //------USART Setup ----
         Close2USART();  //turn off usart if was previously on
         spbrg = 51;
         Open2USART(USART_TX_INT_OFF &
                    USART_RX_INT_OFF &
                    USART_ASYNCH_MODE &
                    USART_EIGHT_BIT &
                    USART_CONT_RX &
                    USART_BRGH_HIGH, spbrg);
         baudconfig = BAUD_8_BIT_RATE & BAUD_AUTO_OFF;
         baud2USART (baudconfig);
    //------USART Transmission ----
        while(Busy2USART());                         //Check if Usart is busy or not
       puts2USART((char *)Txdata);                //transmit the string
     void Delay1Second()
    •   Alt5th March 2015, 14:48
  2. #2
    Advanced Member level 2
    Points: 6,608, Level: 19
    Kurenai_ryu's Avatar
    Join Date
    Jun 2006
    161 / 161
    Re: USART connection between two PIC18F Starter Kits
    Aaaaalways test your communications with a known host.. like communicating each board with a PC first... (go buy a cheap usb/ttl cable to test )
    then, what compiler are you using? It seems XC8 but...
    finally... did you read the XC8 Peripheral Library Manual? it seems you need to use the OR operator '|' to join the settings
         Open2USART(USART_TX_INT_OFF |
                    USART_RX_INT_OFF |
                    USART_ASYNCH_MODE |
                    USART_EIGHT_BIT |
                    USART_CONT_RX |
         baudconfig = BAUD_8_BIT_RATE | BAUD_AUTO_OFF;
    also avoid trying to lock/unlock the PPS, it comes unlocked and for your test it should be enough... (sadly locking/unlocking isn't as easy as setting it to 1 or 0... please read the datasheet for the correct sequence. for the time being, avoid that stuff)
    K~ Ryu
    ~"Sorry my bad english, my native language is C "
