+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Advanced Member level 5
    Points: 14,931, Level: 29
    Achievements:
    7 years registered
    neazoi's Avatar
    Join Date
    Jan 2008
    Greece
    Posts
    3,032
    Points
    14,931
    Level
    29
    Frequency to voltage converter to 30MHz (simple)
    AD650 seems a good solution but it is only suited to 1MHz.
    Any other solutions?
    Professional engineering is the top, but amateur engineering is more fun.
    It is when you cross the barrier between these two, that things become really fascinating!
    •   Alt20th February 2015, 09:21
      advertising
  2. #2
    Banned
    Points: 1,100, Level: 7
    Join Date
    Jan 2013
    Chennai
    Posts
    110
    Points
    1,100
    Level
    7
    Re: Frequency to voltage converter to 30MHz (simple)
    It is better to design by your own instead of going for an IC for 30MHz. I don't think that you will be able to find it out easily when you started looking for a part.
    1 members found this post helpful.
    •   Alt20th February 2015, 09:47
      advertising
  3. #3
    Super Moderator
    Points: 47,105, Level: 53
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,756
    Points
    47,105
    Level
    53
    Here is what could be called simple.
    A high-pass filter. The higher the frequency, the greater the amplitude,
    Values must be adjusted until you find a range of linear response.
    The peak detector requires a diode suitable for the fast frequency.
    •   Alt20th February 2015, 21:49
      advertising
  4. #4
    Points: 34,469, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,667
    Points
    34,469
    Level
    45
    Blog Entries
    7
    Basically a Tachometer is a 1shot per cycle averaged into a Low Pass Filter.
    0 to 30MHz would require a 1/30 us 1-shot or 33ns or less.
    The unknown part is your spec for the input waveform, as errors can occur with any F2V convertor unless the input has well defined constraints. such as harmonics, noise, amplitude sensitivity, slew rate input range Vpp and maximum noise.
    WIth these types of constraints you can define the best solution with a simple diode detector, ECL slicer or Linear comparator, or similar such limiter to trigger a fixed charge into a bigger capacitor and take the average voltage.. THese choices also affect the lower freq limit.
    If you need response to 1kHz the design would look different and requires over 3 decades of linearity and SNR in the output.
    The purpose of F2V converter is a simple tach. Complex ones with narrow band use linear PLL's
    I once designed a 10Mbps SCADA system which also had some DC drive motors with current sensing.
    I had no more Digital channels to support the data, since it was low bandwidth, I used a spare bit in a signalling channel as a one shot from 0 to 1KHz. So the DC was converted to F as a 1 shot using a S/R latch to send a "1" bit only once per input signal cycle and then regenerating the 1-shot at the Receiver console to display the motor current on an Analog Panel Meter. ( circa '77)
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
