+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 2
    Points: 1,708, Level: 9
    Join Date
    Aug 2011
    Dublin, Ireland
    Posts
    143
    Points
    1,708
    Level
    9
    Does offset in an OTA reduce its open loop gain?
    Hello all,
    I understand that the larger the gain the less the effect of offset since the more its impact on the output is supressed.
    But does offset itself reduce gain?
    Say my input diff pair contributes significant Vt mismatch leading to offset. Would this reduce my Aol?
    Thanks,
    Diarmuid
    •   Alt16th February 2015, 22:33
      advertising
  2. #2
    Advanced Member level 5
    Points: 35,382, Level: 45
    Join Date
    Mar 2008
    USA
    Posts
    5,677
    Points
    35,382
    Level
    45
    Re: Does offset in an OTA reduce its open loop gain?
    Not offset per se. But if you operate a dead-balanced
    front end away from null (like for example, putting a
    Vdiff=0 input to a Vio=2mV op amp sample) you will
    reduce the observed AVOL about Vdiff=0 (it will be
    better at Vdiff=2mV).
    This is why op amp ATE setups tend to be closed loop
    with substantial gain elsewhere, so that the input can
    be forced to wherever works best.
    If you ran a fine grained DC analysis and looked at
    deriv(Vout)/derive(Vin) you should see the gain peak
    right at Vio.
    So what you get at Vin=0 will be less. But AVOL may
    or may not be measured with Vin pinned that way,
    depending on who's doing the testing.
    1 members found this post helpful.
    •   Alt17th February 2015, 00:36
      advertising
  3. #3
    Full Member level 2
    Join Date
    Aug 2011
    Dublin, Ireland
    Posts
    143
    Points
    1,708
    Level
    9
    Thanks that makes sense.
    Just to make sure Im am understanding clearly:
    Say I have an NMOS diff pair. The -ve terminal NMOS has a Vt shifted by +2mV.
    => Avol is max when Vin(-ve) is +2mV above Vin(+ve).
    If both Vts were the same (and ignoring other offset sources), Avol would be max when Vin(-ve) = Vin(+ve).
    Is this what you mean?
    •   Alt17th February 2015, 10:26
      advertising
  4. #4
    Points: 39,702, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,689
    Points
    39,702
    Level
    48
    Quote Originally Posted by diarmuid View Post
    Hello all,
    I must admit that I don`t understand your question.
    At first sight, both amplifier properties (offset, gain) are not coupled to each other.
    However, the situation changes when FEEDBACK comes into play.
    Are you speaking of feedback?
    Feedback reduces the gain and, hence, the dc offset at the output caused by an input offset.
  5. #5
    Full Member level 3
    Points: 1,824, Level: 9
    Join Date
    Jan 2010
    Posts
    172
    Points
    1,824
    Level
    9
    There is no relation between gain and the input offset voltage. However in closed loop, if there is a high input voltage then it will reflect into the output current as increased error.
    •   Alt17th February 2015, 11:11
      advertising
  6. #6
    Points: 17,767, Level: 32
    Achievements:
    7 years registered
    crutschow's Avatar
    Join Date
    Feb 2012
    L.A. USA Zulu -8
    Posts
    3,479
    Points
    17,767
    Level
    32
    Offset appears at the output multiplied by the closed-loop gain.
    The open loop gain has little effect on that other than whatever effect it has on the closed-loop gain.
    Zapper
    Curmudgeon Elektroniker
