+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Points: 283, Level: 3
    Join Date
    Jan 2014
    Posts
    Points
    283
    Level
    MSP430 EZ430-RF2500 Servo interface problem
    I'm trying to control a TowerPro SG90 servo from my ez430-rf2500 board. I'm able to configure the Timers for PWM operation but there's absolutely no response from the servo. Just a small jerk at start and nothing.
    As far as the connections are concerned, I've connected the grounds of ez430, servo and separate USB power supply for the servo to a common point. The pin 2.2 of the MCU is connected to the signal wire of the servo. The servo is powered by a USB power supply as mentioned earlier. Here's my code:-
    [syntax=c]#include "msp430f2274.h"
    #define MCU_CLOCK 1100000
    #define PWM_FREQUENCY 46 // In Hertz, ideally 50Hz.
    #define SERVO_STEPS 180 // Maximum amount of steps in degrees (180 is common)
    #define SERVO_MIN 700 // The minimum duty cycle for this servo
    #define SERVO_MAX 3000 // The maximum duty cycle
    unsigned int PWM_Period = (MCU_CLOCK / PWM_FREQUENCY); // PWM Period
    unsigned int PWM_Duty = 0; // %
    void main (void){
    unsigned int servo_stepval, servo_stepnow;
    unsigned int servo_lut[ SERVO_STEPS+1 ];
    unsigned int i;
    // Calculate the step value and define the current step, defaults to minimum.
    servo_stepval = ( (SERVO_MAX - SERVO_MIN) / SERVO_STEPS );
    servo_stepnow = SERVO_MIN;
    // Fill up the LUT
    for (i = 0; i < SERVO_STEPS; i++) {
    servo_stepnow += servo_stepval;
    servo_lut[i] = servo_stepnow;
    // Setup the PWM, etc.
    WDTCTL = WDTPW + WDTHOLD; // Kill watchdog timer
    TACCTL1 = OUTMOD_7; // TACCR1 reset/set
    TACTL = TASSEL_2 + MC_1; // SMCLK, upmode
    TACCR0 = PWM_Period-1; // PWM Period
    TACCR1 = PWM_Duty; // TACCR1 PWM Duty Cycle
    P2DIR |= BIT2; // P2.2 = output
    P2SEL |= BIT2; // P2.2 = TA1 output
    // Main loop
    while (1){
    // Go to 0°
    TACCR1 = servo_lut[0];
    __delay_cycles(100000);
    // Go to 45°
    TACCR1 = servo_lut[45];
    // Go to 90°
    TACCR1 = servo_lut[90];
    // Go to 180°
    TACCR1 = servo_lut[179];
    // Move forward toward the maximum step value
    TACCR1 = servo_lut[i];
    __delay_cycles(20000);
    // Move backward toward the minimum step value
    for (i = SERVO_STEPS; i > 0; i--) {
    }[/syntax]Could someone tell me what I'm missing here? The code compiles perfectly.
    •   Alt18th January 2015, 12:34
      advertising
  2. #2
    Advanced Member level 3
    Points: 5,481, Level: 17
    Join Date
    Apr 2011
    Posts
    926
    Points
    5,481
    Level
    17
    Re: MSP430 EZ430-RF2500 Servo interface problem
    I think your pin configuration is wrong msp430 EZ430 comes with msp430f2274 controller and form its pin diagram your PWM pin must be P2.3 for TA1 P2.2 is TA0 any nice copy from here http://mitchtech.net/msp430-launchpad-pwm/
    Click image for larger version.
    strongly recommended to check the PWM before giving to servo.
    1 members found this post helpful.
    •   Alt19th January 2015, 08:13
      advertising
  3. #3
    Join Date
    Jan 2014
    Posts
    Points
    283
    Level
    Thanks! I was fiddling with TA1 while checking the TA0 pin. Just one last question.
    Do the +V & the Signal pin of the servo need to work at the same voltage levels for proper operation or can the signal be 3.3V while the +V be 5V?
    •   Alt19th January 2015, 19:39
      advertising
  4. #4
    Join Date
    Apr 2011
    Posts
    926
    Points
    5,481
    Level
    17
    I think both works good at 3.3v level you can see the link in my previous post.
  5. #5
    Super Moderator
    Points: 8,197, Level: 21
    Join Date
    Jun 2009
    Japan
    Posts
    1,056
    Points
    8,197
    Level
    21
    Hello!
    Ok, apparently you solved the problem.
    However, here are a few remarks about your program:
    1. The watchdog timer should be the absolute first action in your program. In your case, you have a loop
    filling the LUT first. Well, it might be short enough to work, but in some other cases, your program will keep
    rebooting, you will not understand why and your hair will turn gray.
    2. You use a lot of __delay_cycles, and that's not the proper way to work because you will just consume
    processor cycles for nothing. Imagine that you want to do other actions, you couldn't by using this technique.
    Apparently you know how to use timers, so why not using a second one to do the whole thing?
    3. In this case, you wouldn't need a while(1) loop.
    Dora
