Problem with running the code for PIC10F2XX
gidimiz
Advanced Member level 1
pic10f2xx led blink
Did any one use the PIC10F2xx. If so:
1. Can you please post the __CONFIG() that you have used.
2. What problems did you incounter if any?
With my chip i can program and everything is fine, but the code is not runing at all!
Even a simple led blink is not working.
Thanks.
Re: PIC10F2XX
I have a PIC10F200 design in front of me right now.
All works as expected, no problems.
With GP3 as I/O, the watchdog disabled and code protection on the configuration word is 0FE3.
Re: PIC10F2XX
I found tyhe problem. There is a bug in the MPLAB! The MPLAB disregards teh _CONFIG() that i wrote in the program. So at the end i had to use the configuration bits in the program itself and not use the CONFIG()
Thanks.
Re: PIC10F2XX
Hi gidimiz!
What MPLAB version You are using?
Gorkin
Re: PIC10F2XX
Using MPLAB 7.00 with Hi-T*ch compiler 8.05PL2.
There is already a bug that i found and Microchip said that they will fix it in the next version.
Im trying to run a simulation on the PIC10F202 with the MPLAB SIM in the debugger Select Tool.
I have the programs set with WDT ( OPTION = 0b01001011; ) ON. In the user manual of the device it states on Table 9-5 that when you come out from " WDT wake up from sleep " TO = 0 and PD = 0.
When I run the simulation I get: TO = 1 and GPWUF = 1. all the rest of the pines in the STATUS registers are zero.
Please advise.
Thanks.
Resolution: Hi,
Yes, this appears to be a bug in the simulator.
I have forwarded this information along to the development
tools group.
I will let you know if they recommend a work around.
Dennis Lehman
Corporate Applications
They sent an email saying there is no work around...
I posted another question regarding this problem. When i will get an answer I will post it here.
Thanks.
