Xilinx Impact gives error when FPGA is configured Via JTAG
auromira
Junior Member level 2
idcode 00001111111111111111111111111110
Hi, when i try to configure my spartan II FPGA via JTAG Xilinx Impact gives me the following error.
ERROR:. +iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:629 - '1': Device IDCODE : 00001111111111111111111111111110
INFO:iMPACT:630 - '1': Expected IDCODE: 0000000001100001100000001001001
Somebody!!!!
Help me........ please.
Best regards,
8)
Hello !
Did you set M0 and other pins to right mode?
Do you use serial slave, master... .... mode?
Did you set the device propertly in project properties?
One of the idea is, try to read device IDCode using Jtag.
Bart
xilinx impact
Bartart said:
Hello !
YES ( MO-1 ,M1-0,M2-1)
I use Boundray scan mode
Yes
If i read the device IDcode it gives the same error
Bart
xilinx device idcode expected
Why are you trying to use a .bsd file and not a .bit file ?
I had the same or very similar problem several times but the solution was
trivial (in fact I don't even remember wht I did).
xilinx bad id code
Hmm....
I had the same error time ago, but I can't remeber what was wrong.
I will think about during night OK!
bart
xilinx impact reads wrong id-code
Hi
I had the same problem with a 95108 cpld. Seems to be an early mask revision of the chip.
Is your chip a brand new one with a recent mask revision ?
expected idcode xilinx
well
it may be caused by one of the following reasons.
1- your spartanII device is an engineering sample (pre production sample)
2- it may use virtex bsdl file instead of spartanII
for more information you can check xilinx archive
regards
xilinx 00001111111111111111111111111110
Hi, impact Returns IDCODE different from the IDCODE In the BSDL file
Returned IDCODE :00001111111111111111111111111110
IDCODE in BSDL File:00000000011000011000000010010011
Could a faulty JTAG cable be a cause of this error .Impact correctly detects the JTAG Cable.
Somebody!!!!
Best regards
impact 583 xilinx
Hello !
After a night thinking about tjis problem, I had remember what was wrong.
I had a bad connection with FPGA board.
The Inpact did not show me any error when initialazing the chain, but when the programming started the error shows up.
P.S. I found this on xilinx site
Good luck bart
impact bsdl error
hi
I have the same problem with xilinx saprtan II (xc2s150).
I connect the cable directly to boundary scan pins in the device through a test board. should I pull-up or pull-down any of these pins? if not what may be the source of problem in my hardware
I had configured a Virtex II device with the same cable and it worked correctly . (but that device was on an Avnet development board)
problem impact xilinx
Hi!
The ID error is also possible if you use ISE 5 or 4 for synthese and ISE 6 or 5 for downloading the bit stream. The problem is in the device bsd file.
Good luck!
Bart
bit file impact
hi
I use ISE 5.1i for both synthesis and downloading the bit stream.( I also installed the service pack but the problem persisted) and I use XST for synthesising.did you mean that I should download the new bsd files from Xilinx?
p.s: I used the same software for cofiguring the virtex II.
mehrara said:
hi
I use ISE 5.1i for both synthesis and downloading the bit stream.( I also installed the service pack but the problem persisted) and I use XST for synthesising..
:not: I don't have any idea, just try to debug your JTAG cable
or instead of bit file assain to impact the device bsd file, you will find it in
$:/xilinx/spartan2/data/
and try to get the device ID.
No if you use the same sw for synthese and uploading there is no need to do that.
Bart
Re: Xilinx Impact gives error when FPGA is configured Via JT
Most likely your cable is too long. Check the signal quality. Last time i encountered this kind of problem, i just shortened the connection.
hi
the problem was due to my cable.
I used an old cable and it worked correctlly.
but I don`t know why I can not program Spartan II with a cable by which I have programmed Virtex-E!
i Found That In Cable IV The Rate Need To Be Reduced To Configure
VIRTEX Devices And PROMs !!!
I also encountered this error (before this error It's ok), I checked as you did up , but the reason is software ,after I reinstalled the ise ,It worked ok again!, try it .
