+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Points: 52, Level: 1
    Join Date
    Oct 2014
    Posts
    7
    Points
    52
    Level
    Assembly instruction cycle for 3 counters delay loops
    Hello forum members,
    I need to know formula of this loop.
    DELAY
    		MOVLW HFF(M)				1
    		MOVWF SAYAC1				1
    Loop1
    		MOVLW H90(N)				1XM
    		MOVWF SAYAC2				1XM
    Loop2
    		MOVLW H50(D)				1xNXM
    		MOVWF SAYAC3				1XNXM
    Loop3
    		DECFSZ SAYAC3,F			(D+1) .N.M
    		GOTO	Loop3					(2.D-2) .N .M
                    DECFSZ SAYAC2,F			(N+1) .M
    		GOTO	Loop2					(2.N-2) . M
                    DECFSZ SAYAC1,F			M+1
    		GOTO	Loop1					2M-2
    RETURN							2
    Formula = 3+4.N+3.M.N ?
    why the formula is not true ?
    •   Alt29th October 2014, 08:12
      advertising
  2. #2
    Advanced Member level 5
    Points: 20,490, Level: 34
    Achievements:
    7 years registered
    Join Date
    May 2009
    Prime Meridian
    Posts
    3,056
    Points
    20,490
    Level
    34
    Re: Assembly instruction cycle for 3 counters delay loops
    A software delay loop is based on the number of instruction to complete that loop.
    Does your formula account for the fact that not all of those instruction are completed in one machine cycle, some like the goto and decf may need 2 machine cycles. ( see the chips data sheet - section Instruction Set Summary.)
    The loop as it stands in just short of 9 million instructions on a Pic16F.
    •   Alt29th October 2014, 16:19
      advertising
  3. #3
    Join Date
    Oct 2014
    Posts
    7
    Points
    52
    Level
    Thanks for helping,
    I used pic16f887.
    I need formula cause of I would like to flexibly projects.
    •   Alt29th October 2014, 17:35
      advertising
  4. #4
    Points: 7,633, Level: 20
    Achievements:
    7 years registered
    paulfjujo's Avatar
    Join Date
    Jun 2008
    France 01120
    Posts
    1,270
    Points
    7,633
    Level
    20
    hello,
    your formula is wrong.. because you are using external loop
    and reinitiate value inside the loop..
    so global is more than M*N*D ..etc ..
    if preferre to use this, from Myke Predo 1997 !
    very universal
    Click image for larger version.
    at 4MHz FOSC , cycle=1S
    mini is with values count1=1,count2=1,count3=1 => 6S
    maxima is with values 255 ,255,255 => 83.559 secondes !!!
    Formula inside the picture...
    1 members found this post helpful.
  5. #5
    Achievements:
    7 years registered
    Join Date
    May 2009
    Prime Meridian
    Posts
    3,056
    Points
    20,490
    Level
    34
    Think that chart paulfjujo shows does just about everything, but for basic delays I find this calculator as easy as it gets.
    http://www.golovchenko.org/cgi-bin/delay
    2 members found this post helpful.
  6. #6
    Join Date
    Oct 2014
    Posts
    7
    Points
    52
    Level
    @wp100
    http://waihung.net/microchip-delay-calculator/
    Please forget easy delay generators .
    I've tried a lot of generator. all generators are different . I am annoyed about this situation.
    So. I need more maths operation for truely delay loops.
    @paulfjujo
    Let me match our math operation .
    Let's write the number of the instruction against the code
                    DELAY
    		MOVLW H50				1
    		MOVWF Count1				1
    Loop1
                    DECFSZ Count1,F			        2+Count1-1  =1+count1
    		GOTO	Loop1					2x(count1-1)= 2xcount1  -2
    RETURN							2
    total = 2 + 1+count1+2count1 -2 +2
    total = 3+3count1
    total = 153instruction cycle .
    please do math operation by same way.
    •   Alt29th October 2014, 20:49
      advertising
  7. #7
    Achievements:
    7 years registered
    Join Date
    May 2009
    Prime Meridian
    Posts
    3,056
    Points
    20,490
    Level
    34
    Quote Originally Posted by BLaacK89 View Post
    @wp100
    @paulfjujo
                    DELAY
    		MOVLW H50				1
    		MOVWF Count1				1
    Loop1
    RETURN							2
    total = 3+3count1
    The Decfsz is only 1 cycle when used in that mode .
    H'50' = decimal 80
    Have you tried using MPlabs SIMulator and Stopwatch, you can Single Step though each instruction or use breakpoints to start and stop code between certain points.
    The Stopwatch increments with each instruction.
