how to save and calculate in spectre
layes2
Full Member level 4
how to save a compent such as ac current and calculate it
for ig :
in hspice
.probe dc i= par('I1(M6)/2')
how to do it in spectre
when you use
' spectre input.scs&'
run the simulation !!!(you cannot you resultbrowse or calculate when use command
simulation as ' spectre input.scs&' )
after running the circuit descrption under spectre command mode few files will be generated and ey contains the parameter values .use wavesacn stanalone utility to see the stored values and plot . or u can save the parameters through command line introduced in cir file. see spectre reference manual for syntax .
i just donot know how to save it and calculate it
i can see it through wave viewer
the reference of spectre donot show it clear
YOu can use analogLib / iprobe , That can show the current information
nono
i mean use command to do it
not
use artist
