+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 3
    Points: 29, Level: 1
    Join Date
    Oct 2014
    Posts
    Points
    29
    Level
    Getting each output twice from LFSR
    Hi.
    I am trying to make a 32'bit LFSR with a given initial state. I am posting the code and stimulus below.
    [syntax=verilog]/*------------------------------------------*/
    module lfsr (clock, reset, out);
    input clock, reset;
    output [31:0] out;
    reg [31:0] temp;
    wire newbit;
    xor (newbit,temp[0],temp[10],temp[30],temp[31]);
    initial
    temp = 32'hffffffff;
    always @(posedge clock)
    begin
    temp <= {newbit,temp[31:1]};
    end
    assign out = temp;
    endmodule
    //Stimulus
    module lfsrstimulus;
    reg CLOCK, RESET;
    wire [31:0] OUT;
    lfsr l1 (CLOCK, RESET, OUT);
    initial
    $monitor($time, "Clock = %b, Output = %b\n", CLOCK,OUT);
    initial
    begin
    CLOCK = 1'b1;
    forever #10 CLOCK = ~CLOCK;
    end
    initial
    #100 $finish;
    endmodule
    /*--------------------------------------------*/[/syntax]
    The problem I am having is that when I run the stimulus, each output comes twice. Is this because of timing delays?
    Thanks in advance for any help. :)
    •   Alt15th October 2014, 14:19
      advertising
  2. #2
    Advanced Member level 5
    Points: 14,946, Level: 29
    mrflibble's Avatar
    Join Date
    Apr 2010
    Posts
    2,724
    Points
    14,946
    Level
    29
    Re: Getting each output twice from LFSR
    No. It is because you choose to confuse yourself. The simulation looks okay. The lfsr gets a new value at every positive going edge of clock. The monitor statement in this case prints the contents of the lfsr registers both when clock is low, and when clock is high. Which is why you perceive it as "double".
    1 members found this post helpful.
  3. #3
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,440
    Points
    28,167
    Level
    40
    use something like:
    [syntax=verilog]@(posedge CLOCK) $display("%t, Output = %b\n", $time, OUT);[/syntax]
    then you'll only see one output each clock
    •   Alt15th October 2014, 16:04
      advertising
  4. #4
    mrflibble's Avatar
    Join Date
    Apr 2010
    Posts
    2,724
    Points
    14,946
    Level
    29
    Another missed learning opportunity of reading the $monitor man page. :( But yes, that is probably the kind of output he's expecting. :)
  5. #5
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,440
    Points
    28,167
    Level
    40
    Utshash should still read the $monitor man page.
    •   Alt15th October 2014, 16:19
      advertising
  6. #6
    mrflibble's Avatar
    Join Date
    Apr 2010
    Posts
    2,724
    Points
    14,946
    Level
    29
    Homo sapiens + path of least resistance equals exactly.
    But I agree. He would do well to read the $monitor documentation. It has a key sentence in it that explains why it shows things the way it does.
  7. #7
    Newbie level 3
    Join Date
    Oct 2014
    Posts
    Points
    29
    Level
    Thank you all. I see my mistake now and as suggested by all of you, I'll read the $monitor documentation. Thanks again. :)
    Thank you all for replying and pointing out my stupidity. As suggested by most of you, I'll try to read the $monitor documentation as soon as possible. Thanks again. :)
  8. #8
    mrflibble's Avatar
    Join Date
    Apr 2010
    Posts
    2,724
    Points
    14,946
    Level
    29
    People that read documentation get free internet cookies!
