[Moved] How to divide any numbers in Verilog
prakhars
Junior Member level 3
Want to divide a number by 21 in verilog code, but it is giving an error saying, Second Operand should be power of 2.
How to perform division of any two numbers in verilog???
hi,
you can use a division ip core for this .
how did you get that error ??
or else you can design a divider. but using division ip core is better(i mean not time consuming).
How to perform division of any two numbers in verilog???[/
it is done by shifting . do you want to design a divider by yourself ?
regards
Yes,. Actually I don't know IP core, so either you can explain how to do division with IP core or you can help me design a Divider,. :)
I am using Xilinx ISE Sim
Thank you so much for your reply, I will work on it and in case I find some difficulty I'll let u know.
hi
sorry for the incomplete reply ads-ee. normally it is done by shifting followed by substraction.before shifting we need to arrange the dividend and divisor in proper manner.
may be other methods are also there...
regards
