Trying to run Nios LED code ?
bianchi77
California
Guys,
I tried to run a code on NIOS,
Here's the log :
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00001810:
    ID value verified
    Timestamp value was not verified: value was not specified
Initializing CPU cache (if present)
OK
Downloading 04000020 ( 0%)
Downloaded 62KB in 2.6s (23.8KB/s)
Verifying 04000020 ( 0%)
Verified OK
Starting processor at address 0x040001B4
but I didn't see any response on the board, anything missing here ?
the code :
#include <io.h>
#include <unistd.h>
#include <system.h>
#include "altera_avalon_pio_regs.h"
#include <stdio.h>
#define msleep(ms)  usleep(1000*ms)
#define DIRECTION_PA(data)  IOWR_ALTERA_AVALON_PIO_DIRECTION(LED_BASE, data)
#define DATA_PA(data)  IOWR_ALTERA_AVALON_PIO_DATA(LED_BASE, data)
int main()
{   printf("hello world");
    DIRECTION_PA(0xFF);
    alt_u8 tmp = 0X01;
    unsigned char i;
    printf("hello");
    while(1)
    {   tmp = 0X01;
        for(i=0;i<4;i++)
        DATA_PA(tmp);
        tmp=tmp<<1;
        msleep(50);
    return 0;
How can I save NIOS code into EPCS16, everytime power supply is gone, I need to burn NIOS again from Quartus II programmer ???
You really need to learn how to go about debugging something. Did you every try setting the LEDs permanently first?
As written the LEDs are going to be dim as you have them cycling on for 50ms out of 200ms.
I got a way already to combine NIOS configuration and NIOS code, thanks...
