Simulating a design with Altera PLL in modelsim
shaiko
Advanced Member level 5
Hello,
I'm trying to simulate a design that uses an ALTPLL (Altera PLL).
This is the entity that uses the "altpll" component.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY altera_mf;
USE altera_mf.all;
ENTITY new_pll IS
PORT
areset : 	IN STD_LOGIC  := '0';
inclk0 : 	IN STD_LOGIC  := '0';
c0 :		OUT STD_LOGIC ;
locked :	OUT STD_LOGIC
END new_pll;
When I compile the design in modelsim design I get the following errors:
# ** Error: C:/new_pll.vhd(42): Library altera_mf not found.
# ** Error: C:/new_pll.vhd(43): near "altera_mf": syntax error
I compiled
"altera_mf.vhd" and "altera_mf_components.vhd" prior that...yet the error does't go away.
What am I doing wrong?
You need to add the Altera libraries to modelsim
Reactions: shaiko
    shaiko
did you compile the files into the altera_mf library?
How ?
Isn't just compiling the VHD files of the required libraries enough?
You have to add the library to modelsim's search path.
look in the ini or mpf file to find the library mapping for the ieee libraries and add the altera_mf library path in the same fashion.
There is a "how-to" in Altara's documentation on setting up the libraries for simulation in Modelsim.
Reactions: shaiko
    shaiko
TrickyDicky,
What do you mean by: "into"?
I just compiled them and tried to compile my design file immediately afterwards. It fails.
Vcom -work altera_mf ....
Reactions: shaiko
    shaiko
I'm not very familiar with the command line interface of Modelsim.
I use the GUI most of the time.
What exactly does the above command do?
How can I do the same with the GUI ?
That's why I suggested adding the libraries in the .mpf or .ini file that Modelsim uses.
If you add the libraries there, then you won't have to use the command line (I run simulations from a script, so for me command line is the norm)
They are simple map commands that tell where to find the location of altera_mf and the other libraries.
I normally just edit the .mpf text file directly, but you can add the changes in via:
http://quartushelp.altera.com/13.1/...mulation/modelsim/eda_pro_msim_setup_proj.htm
Reactions: shaiko
    shaiko
