[SOLVED] Suggestions for CISC and RISC cores for university use
dpaul
Advanced Member level 5
Germany
Hello all,
We are looking for CISC(x86) and RISC uP cores to be used in university research projects. We can also pay licensing fees upto a certain amount (which is of course not a significant amount).
We should be able to implement this core in an FPGA(pref. Xilinx) with the availability of popular i/f (USB/JTAG/etc) and then use some popular tool-chains.
Main target is to do some RTL level h/w changes and then work on tweaking the instruction set and work @compiler level.
What options are out there OTHER THAN the ones @OpenCores, Leon3 SPARC dev platform and the one through the ARM Uni Program (ARM Cortex-M0 DesignStart Processor)?
Please share your comments, suggestions and experiences.
Thanks.
You have microblaze and picoblaze fpr Xilinc FPGA. You can even ypu PowerPC core
Picoblaze is royalty. free available. under BSD license.
Reactions: dpaul
    dpaul
We have finally decided to go with Raspberry Pi since it is having an ARM core that supports ARM & Thumb instruction sets. It can also support Linux and WinCE.
