[SOLVED] HELP: PIC16F877A Input-Based 7segdisplay using Functions &Procedures
RannieKnows
Junior Member level 1
Good day!
We are asked to output the numbers in 7segmentdisplay via PORTD, using functions &/or procedures. Please help me.
Example. If I pressed RC0, 7seg will output "1". But the program will not be directly from MAIN. We are required to use sub function… or sub procedure syntax.
if you do a forum search for LCD PIC16 you will find many posts on this topic
