angy
Full Member level 3
I have written a code for SPI communication when I run and debug it does not receive data.
What may be the problem at line #153?
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 ****************************************************************************** * @file SPI/CRC/main.c * @author MCD Application Team * @version V3.5.0 * @date 08-April-2011 * @brief Main program body ****************************************************************************** * @attention * * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. * * <h2><center>© COPYRIGHT 2011 STMicroelectronics</center></h2> ****************************************************************************** */ /* Includes ------------------------------------------------------------------*/ #include "stm32f10x_gpio.h" #include "stm32f10x_rcc.h" #include "stm32f10x_spi.h" #include "platform_config.h" /** @addtogroup STM32F10x_StdPeriph_Examples * @{ */ /** @addtogroup SPI_CRC * @{ */ /* Private typedef -----------------------------------------------------------*/ typedef enum {FAILED = 0, PASSED = !FAILED} TestStatus; /* Private define ------------------------------------------------------------*/ #define BufferSize 32 /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ SPI_InitTypeDef SPI_InitStructure; uint16_t SPI1_Buffer_Tx[BufferSize] = {0x0102, 0x0304, 0x0506, 0x0708, 0x090A, 0x0B0C, 0x0D0E, 0x0F10, 0x1112, 0x1314, 0x1516, 0x1718, 0x191A, 0x1B1C, 0x1D1E, 0x1F20, 0x2122, 0x2324, 0x2526, 0x2728, 0x292A, 0x2B2C, 0x2D2E, 0x2F30, 0x3132, 0x3334, 0x3536, 0x3738, 0x393A, 0x3B3C, 0x3D3E, 0x3F40}; uint16_t SPI2_Buffer_Tx[BufferSize] = {0x5152, 0x5354, 0x5556, 0x5758, 0x595A, 0x5B5C, 0x5D5E, 0x5F60, 0x6162, 0x6364, 0x6566, 0x6768, 0x696A, 0x6B6C, 0x6D6E, 0x6F70, 0x7172, 0x7374, 0x7576, 0x7778, 0x797A, 0x7B7C, 0x7D7E, 0x7F80, 0x8182, 0x8384, 0x8586, 0x8788, 0x898A, 0x8B8C, 0x8D8E, 0x8F90}; uint16_t SPI1_Buffer_Rx[BufferSize], SPI2_Buffer_Rx[BufferSize]; uint32_t TxIdx = 0, RxIdx = 0; __IO uint16_t CRC1Value = 0, CRC2Value = 0; volatile TestStatus TransferStatus1 = FAILED, TransferStatus2 = FAILED; /* Private functions ---------------------------------------------------------*/ void RCC_Configuration(void); void GPIO_Configuration(void); TestStatus Buffercmp(uint16_t* pBuffer1, uint16_t* pBuffer2, uint16_t BufferLength); /** * @brief Main program * @param None * @retval None */ int main(void) { /*!< At this stage the microcontroller clock setting is already configured, this is done through SystemInit() function which is called from startup file (startup_stm32f10x_xx.s) before to branch to application main. To reconfigure the default setting of SystemInit() function, refer to system_stm32f10x.c file */ /* System clocks configuration ---------------------------------------------*/ RCC_Configuration(); /* GPIO configuration ------------------------------------------------------*/ GPIO_Configuration(); /* SPI1 configuration ------------------------------------------------------*/ SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; SPI_Init(SPI1, &SPI_InitStructure); /* SPI2 configuration ------------------------------------------------------*/ SPI_InitStructure.SPI_Mode = SPI_Mode_Slave; SPI_Init(SPI2, &SPI_InitStructure); /* Enable SPI_MASTER TXE interrupt */ // SPI_I2S_ITConfig(SPI_MASTER, SPI_I2S_IT_TXE, ENABLE); /* Enable SPI_SLAVE RXNE interrupt */ // SPI_I2S_ITConfig(SPI_SLAVE, SPI_I2S_IT_RXNE, ENABLE); /* Enable SPI1 CRC calculation */ SPI_CalculateCRC(SPI1, ENABLE); /* Enable SPI2 CRC calculation */ SPI_CalculateCRC(SPI2, ENABLE); /* Enable SPI1 */ SPI_Cmd(SPI1, ENABLE); /* Enable SPI2 */ SPI_Cmd(SPI2, ENABLE); /* Transfer procedure */ while (TxIdx < BufferSize - 1) { /* Wait for SPI1 Tx buffer empty */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); /* Send SPI2 data */ SPI_I2S_SendData(SPI2, SPI2_Buffer_Tx[TxIdx]); /* Send SPI1 data */ SPI_I2S_SendData(SPI1, SPI1_Buffer_Tx[TxIdx++]); /* Wait for SPI2 data reception */ while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET); /* Read SPI2 received data */ SPI2_Buffer_Rx[RxIdx] = SPI_I2S_ReceiveData(SPI2); /* Wait for SPI1 data reception */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); /* Read SPI1 received data */ SPI1_Buffer_Rx[RxIdx++] = SPI_I2S_ReceiveData(SPI1); } /* Wait for SPI1 Tx buffer empty */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET); /* Wait for SPI2 Tx buffer empty */ while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET); /* Send last SPI2_Buffer_Tx data */ SPI_I2S_SendData(SPI2, SPI2_Buffer_Tx[TxIdx]); /* Enable SPI2 CRC transmission */ SPI_TransmitCRC(SPI2); /* Send last SPI1_Buffer_Tx data */ SPI_I2S_SendData(SPI1, SPI1_Buffer_Tx[TxIdx]); /* Enable SPI1 CRC transmission */ SPI_TransmitCRC(SPI1); /* Wait for SPI1 last data reception */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); /* Read SPI1 last received data */ SPI1_Buffer_Rx[RxIdx] = SPI_I2S_ReceiveData(SPI1); /* Wait for SPI2 last data reception */ while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET); /* Read SPI2 last received data */ SPI2_Buffer_Rx[RxIdx] = SPI_I2S_ReceiveData(SPI2); /* Wait for SPI1 data reception: CRC transmitted by SPI2 */ while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); /* Wait for SPI2 data reception: CRC transmitted by SPI1 */ while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET); /* Check the received data with the send ones */ TransferStatus1 = Buffercmp(SPI2_Buffer_Rx, SPI1_Buffer_Tx, BufferSize); TransferStatus2 = Buffercmp(SPI1_Buffer_Rx, SPI2_Buffer_Tx, BufferSize); /* TransferStatus1, TransferStatus2 = PASSED, if the data transmitted and received are correct */ /* TransferStatus1, TransferStatus2 = FAILED, if the data transmitted and received are different */ /* Test on the SPI1 CRC Error flag */ if ((SPI_I2S_GetFlagStatus(SPI1, SPI_FLAG_CRCERR)) == SET) { TransferStatus2 = FAILED; } /* Test on the SPI2 CRC Error flag */ if ((SPI_I2S_GetFlagStatus(SPI2, SPI_FLAG_CRCERR)) == SET) { TransferStatus1 = FAILED; } /* Read SPI1 received CRC value */ CRC1Value = SPI_I2S_ReceiveData(SPI1); /* Read SPI2 received CRC value */ CRC2Value = SPI_I2S_ReceiveData(SPI2); while (1) {} } /** * @brief Configures the different system clocks. * @param None * @retval None */ void RCC_Configuration(void) { /* PCLK2 = HCLK/2 */ RCC_PCLK2Config(RCC_HCLK_Div2); /* Enable peripheral clocks --------------------------------------------------*/ /* GPIOA, GPIOB and SPI1 clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_SPI1, ENABLE); /* SPI2 Periph clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE); } /** * @brief Configures the different GPIO ports. * @param None * @retval None */ void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; /* Configure SPI1 pins: SCK, MISO and MOSI ---------------------------------*/ /* Confugure SCK and MOSI pins as Alternate Function Push Pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Confugure MISO pin as Input Floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOA, &GPIO_InitStructure); /* Configure SPI2 pins: SCK, MISO and MOSI ---------------------------------*/ /* Confugure SCK and MOSI pins as Input Floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_15; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOB, &GPIO_InitStructure); /* Confugure MISO pin as Alternate Function Push Pull */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOB, &GPIO_InitStructure); } /** * @brief Compares two buffers. * @param pBuffer1, pBuffer2: buffers to be compared. * @param BufferLength: buffer's length * @retval PASSED: pBuffer1 identical to pBuffer2 * FAILED: pBuffer1 differs from pBuffer2 */ TestStatus Buffercmp(uint16_t* pBuffer1, uint16_t* pBuffer2, uint16_t BufferLength) { while (BufferLength--) { if (*pBuffer1 != *pBuffer2) { return FAILED; } pBuffer1++; pBuffer2++; } return PASSED; }
