+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Junior Member level 3
    Points: 4,493, Level: 15
    Join Date
    Jul 2001
    Posts
    31
    Points
    4,493
    Level
    15
    tl431 spice model
    Does someone have a SPICE model for the TL431/LM431/KA431 shunt regulator?
    Thanks.
  2. #2
    sick_man
    lm431 spice model
    h*tp://w8w.fairchildsemi.com/models/spice/
    try here
  3. #3
    sick_man
    tl431 spice
    this is how i got it
    i open a new browser
    go to google.com
    and type lm431 spice model
    sometimes caps and space between lm and the number etc make a big dif too what reply you get from an engine
    google is the best
    the rest use it as an engine hehehe
  4. #4
    Join Date
    Jul 2001
    Posts
    31
    Points
    4,493
    Level
    15
    tl431 pspice
    Hi, I found it in a library I discharged form TI ages ago (and now not available, I'm thinking to crate a public depository for those libraries, maybe on the FM...).
    Thanks for your effort.
    P.S. I agre in your opinion on Google.
  5. #5
    Member level 2
    Points: 5,366, Level: 17
    Join Date
    Sep 2001
    USA
    Posts
    45
    Points
    5,366
    Level
    17
    lm431 spice
    Hi,I need the TL431 Spice model too.
    can you please post in FM or send to me as PM.
    Thanks a lot!
    Sonic
  6. #6
    Newbie level 6
    Points: 3,972, Level: 14
    Join Date
    Jan 2000
    Posts
    14
    Points
    3,972
    Level
    14
    tl431 pspice model
    hi guys,here's the model for TL431 from Intusoft:
    *SRC=TL431;TL431;Voltage Ref.;;
    *SYM=TL431
    .SUBCKT TL431 7 6 11
    * K A FDBK
    .MODEL DCLAMP D (IS=13.5N RS=25M N=1.59
    + CJO=45P VJ=.75 M=.302 TT=50.4N BV=34V IBV=1MA)
    V1 1 6 2.495
    R1 6 2 15.6
    C1 2 6 .5U
    R2 2 3 100
    C2 3 4 .08U
    R3 4 6 10
    G2 6 8 3 6 1.73
    D1 5 8 DCLAMP
    D2 7 8 DCLAMP
    V4 5 6 2
    G1 6 2 1 11 0.11
    .ENDS
  7. #7
    Newbie level 1
    Points: 94, Level: 1
    Join Date
    Jun 2012
    Posts
    Points
    94
    Level
    Re: tl431 pspice model
    I find this post because I was researching a spice model for TL431. The model's Javier from Intusoft, it's not a good model because it can't simulate a shunt regulator for example.
    But I find here a good spice model developed by Eugene Dvoskin.
    I simulated a shunt regulator in LTspice with Eugene Dvoskin's Model. And it was in harmony with the theory (VZ = VREF (1 + R1/R2) + IREF*R1).
    I give you the .spice
    .subckt TL431ED K A ADJ
    Q1 K ADJ N005 0 QN_ED
    Q7 N003 N003 N001 0 QP_ED
    D1 A N004 D_ED
    Q8 N004 N003 N002 0 QP_ED
    R4 N005 N009 3.28k
    R2 N009 N012 2.4k
    R3 N009 N010 7.2k
    R1 N014 A 800
    R5 N006 N011 4k
    R7 K N001 800
    R8 K N002 800
    R6 N013 N012 1k
    R9 N008 N007 150
    R10 N008 A 10k
    D2 A K D_ED
    C1 K N004 10p
    C2 N010 N011 20p
    Q2 N012 N012 A 0 QN_ED area=1.2
    Q3 N010 N012 N014 0 QN_ED area=2.2
    Q5 N011 N010 A 0 QN_ED
    Q9 K N004 N007 0 QN_ED
    Q10 K N008 A 0 QN_ED area=5
    Q4 N003 N005 N006 0 QN_ED
    Q6 N004 N013 A 0 QN_ED area=0.5
    Q11 N004 N004 ADJ 0 QN_ED
    .model D D
    .lib C:\PROGRA~1\LTC\LTSPIC~1\lib\cmp\standard.dio
    .model NPN NPN
    .model PNP PNP
    .lib C:\PROGRA~1\LTC\LTSPIC~1\lib\cmp\standard.bjt
    .model QN_ED NPN(BF=140 Cje=1p Cjc=2p Rb=40 VAF=80 VAR=50 KF=3.2e-16 AF=1)
    .model QP_ED PNP(BF=60 Cje=1p Cjc=3p Rb=80 VAF=70 VAR=40)
    .MODEL D_ED D(Rs=5 CJ0=4.0p)
    * Model developed by Eugene Dvoskin --> "http://www.audio-perfection.com"  02/05/2012\nThis TL431 model has been developed from schematic in the datasheet\nhttp://www.ti.com/lit/ds/symlink/tl431.pdf\nIt matches most of DC, AC, Transient, Stability and Noise performance of TI TL431\nNo attempts were made to cover Temperature dependences
    .backanno
    .end
