+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 1
    Points: 498, Level: 4
    Join Date
    Oct 2013
    Posts
    36
    Points
    498
    Level
    what does these terms mean in hfss
    can anybody please tell what does the following terms mean in hfss?
    1-radiation boundry
    2-number of passes
    3-frequency sweep
    4-add trace
    •   Alt14th June 2014, 18:00
      advertising
  2. #2
    Member level 3
    Points: 1,945, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jan 2009
    Posts
    63
    Points
    1,945
    Level
    10
    Re: what does these terms mean in hfss
    1- radiation buondry means the space that you should define as a farfield area and make it as an radiation , so your device can radiate in far field. thid area should be more than 10*lambda
    2- to calculate the equations, HFSS has some passes, if the difference between two results in each passes is less than for example 0.02 (that yourself define it), the calculation finished. if not, untill number of passe that you yourself define, the calculation will stop.
    3- frequency sweep means the range of frequency that our model will simulate on all of that frequencies with step size that you define.
    4-add trace used for see two or more graphs in one figure.
  3. #3
    Member level 1
    Join Date
    Oct 2013
    Posts
    36
    Points
    498
    Level
    ok so i take it as a loop that it will repeat the calculations 2000 times for that equation ....
    •   Alt15th June 2014, 09:57
      advertising
  4. #4
    Member level 5
    Points: 1,030, Level: 7
    Join Date
    Dec 2013
    Jupiter
    Posts
    81
    Points
    1,030
    Level
    7
    Hi.
    I haven't understant about Solution Frequency in HFSS?
    Should it be the center frequency of Frequency Sweep or the maximal frequency or the desired frequency? Which one has the most exact result?
    My teacher told me that It should be the maximum frequency of Sweep. Is this right?
  5. #5
    Member level 3
    Achievements:
    7 years registered
    Join Date
    Jan 2009
    Posts
    63
    Points
    1,945
    Level
    10
    in setup you set a solution frequency ((solution freq is a freq that the circuit or antenna designed at this freq)), then you right click on setup and set sweep frequency range ((to see the behavior of designed antenna on the other frequencies near the solution freq in a band with)),
    •   Alt16th June 2014, 15:27
      advertising
  6. #6
    Member level 1
    Join Date
    Oct 2013
    Posts
    36
    Points
    498
    Level
    ok and what about the antenna design kit?
    i think there is not much stuff about it on the internet
  7. #7
    Newbie level 3
    Points: 548, Level: 4
    Join Date
    Jan 2013
    Posts
    Points
    548
    Level
    The radiation boundary should be > lambda/4 from the radiating surface in this case the patch. There's no harm the radiation boundary being lambda/4 away all around the antenna.
    1 members found this post helpful.
