What happens when concat STD_LOGIC into STD_LOGIC_VECTOR
legendbb
Member level 1
Let's say I have 32 independent STD_LOGIC signal each transits on independent logics.
Just being lazy about output port, if I concatenate them into a STD_LOGIC_VECTOR(31 DOWNTO 0). What the impact of this assignment would have for FPGA implementation?
Would this end up with less resource usage or potential timing routing issue?
I assume if I don't register this STD_LOGIC_VECTOR, tool will take it as nets; if I register this signal, logic is different.
Please comment,
Thanks,
Concatenation is just bundling of signals (hence think wires) and should not increase or decrease the amount of logic required by the rest of the circuit.
Thanks a lot for your reply.
