SPDIF Transmitter & Receiver Design
tony_taoyh
Full Member level 2
spdif transmitter
Hi, all,
Is there anyone who have implement the SPDIF receiver and transmitter?
Can you give me some idea for it?
(1) For the receiver:
Can I use pure digital method to decode it?
So that I do not need to use CDR...
For example, I can use oversampler...
(2) For the transmitter:
Can I use a high freq clock to send out the SPDIF data?
for example, 100Mhz...
The output spdif sample rate is 48K, 96K, and 192K...
I think this method will bring big jitter...
Is it acceptable...
This method can avoid to use PLL to generate the spdif bit clock...
Can we discuss this issue??
Thanks a lot.
Best Regards,
Tony
spdif transmitor
Hi. Here is finished SPDIF Receiver/Transmiter IP core:
\**broken link removed**
Best Regards.
spdif receiver
i think you must use CDR to decode
