How to design an inverter buffer to drive a 1pF capacitance?
triquent
Full Member level 3
how to calculate fan out of a buffer
If I want to design an inverter buffer to drive a 1pF capacitance. What is the minimum fan-out of the inverter to make the output waveform ok if don't consider the speed. how to calculate the needed fanout? or do it by simulation?
Added after 3 minutes:
is it usually the minimum fanout should be 1?
Re: how to design a buffer?
you want to design a std cell. or infer the buffer in your logic?
what's the difference?
1) output buffer fanout=?
2) internel buffer fanout=?
I mean a full customer design.
Since you are doing a full custom design, you are better off doing the simulation rather than trying to get the fan out no.. This fan out no. is normally only used in digital design where the gates are standard sizes. And if you don't want to consider the speed, then almost any reasonable gate size will do. Then again, if you are trying to drive something off-chip, you should go for a foundry provided buffer.
hi
read book by Rabey (digital integrated circuit).it has given good example about Buffer design
Hey,
generally...they fanout of any buffer is gain "1"....
and also it depends on the output capacitance of the transistor....
basically...you need to consider the input and output gain of the transistor.....which you are placing for designing the Buffer...and then....come the speed.......generally...if you consider...Buffer model....it may vary...depending on what kind of transistor model you are using...
all calculations etc.. you can refer.....digital integrated circuits
In theory, you can make an inverter chain with proper sizing to speed up the signal, if you know the loading capacitance. However, in reality, the calculated transistor size might be too large. So just use some approximation for the inverter chain sizing. Hope this helps.
Eric
Well regarding this I will say that you refer to LOGICAL EFFORT by David Harris...
It is the excellent book dealing with these aspects...
