+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Junior Member level 2
    Points: 1,619, Level: 9
    Join Date
    Oct 2004
    Posts
    22
    Points
    1,619
    Level
    9
    mosfet what is typical gm value
    e. g Width and Length etc
  2. #2
    Advanced Member level 1
    Points: 4,719, Level: 16
    Join Date
    Sep 2004
    Posts
    461
    Points
    4,719
    Level
    16
    w/l ratio typical value
    Typical value of MOSFET for what? W/L = 10u/0.18u, 1u/0.18, 10u/0.6u, 1000u/0.6u
    minimum dimensions are set by technology design rules. Max - whatever.
    Question like that does not have answer.....
  3. #3
    Join Date
    Oct 2004
    Posts
    22
    Points
    1,619
    Level
    9
    mosfet typical length analog design
    Thanks Teddy. Im trying to design an analog delay line as my undergraduate project. my supervisor has asked me to work out the W/L of the CMOS 0.35u. I believe chosing the W/L can vary the transconductance and/or reduce the Vgs drop across the Mosfet. am i correct?
    Thanks
    •   Alt2nd February 2005, 02:52
      advertising
  4. #4
    Member level 2
    Points: 1,699, Level: 9
    Join Date
    Jan 2005
    Posts
    44
    Points
    1,699
    Level
    9
    Re: what is the typical value of Mosfet?
    You'll have to find out what your target gm is and plug in the figures into the formula to get an approximation of the W/L. Your Vgs and Vds has to be large enough to keep it in saturation too. Consult your 0.35um process manual for other figures. Your min. length should be 0.35um.
    1 members found this post helpful.
    •   Alt2nd February 2005, 08:56
      advertising
  5. #5
    Join Date
    Oct 2004
    Posts
    22
    Points
    1,619
    Level
    9
    how do i find a target gm?
    •   Alt2nd February 2005, 12:41
      advertising
  6. #6
    Join Date
    Sep 2004
    Posts
    461
    Points
    4,719
    Level
    16
    I personaly would start from the "Spec". What should be the minimum delay, max delay, is it variable delay or fixed delay, should it be differential or not?
    What size are your I/Os or is it just block without any output spec? (VOH, VOL etc)
    You should probably make a calculation of the "stage" delay ( I am sure you had it during the course) and based on the calculation and the spec. you should be able to figure that out.
    If you want just to put something quick together I would say 5/0.35 seems quite reasonable .... (though a little big)
  7. #7
    Join Date
    Oct 2004
    Posts
    22
    Points
    1,619
    Level
    9
    Thanks, what I meant by the delay line is actually an analog shift register. it really is just connecting a bunch of S/H circuit and a few buffer together.
    say I want to make a switch for the simple S/H circuit what gm should it be?
  8. #8
    Member level 1
    Points: 1,735, Level: 9
    Join Date
    Apr 2004
    Posts
    33
    Points
    1,735
    Level
    9
    It depends on the speed requirement.
  9. #9
    Member level 2
    Join Date
    Jan 2005
    Posts
    44
    Points
    1,699
    Level
    9
    Quote Originally Posted by ug02048
    Finding a MOS switch size for a S/H is a different kettle of fish. In this case, you won't need to know the gm. You should concentrate on the ON resistance of the MOS. Try looking up Phillip Allen's book for MOS switches. You also don't want to make it too big, otherwise you'll get clock feed through.
  10. #10
    Member level 5
    Points: 1,831, Level: 9
    Join Date
    Jan 2005
    Posts
    90
    Points
    1,831
    Level
    9
    MOSFET is voltage controlled device and its properties mainly based on W/L ratio i'e width and length.L shows the technology you are using
    •   Alt3rd February 2005, 03:57
      advertising
  11. #11
    Full Member level 3
    Points: 2,866, Level: 12
    Join Date
    Jul 2004
    Posts
    160
    Points
    2,866
    Level
    12
    length of the mosfet totally depends upon the technology u r using.then according to specification/s u can determine the width of the transistor
  12. #12
    Member level 1
    Points: 1,606, Level: 9
    Join Date
    Jan 2005
    Posts
    41
    Points
    1,606
    Level
    9
    Quote Originally Posted by Teddy
    that's not true. minimum length is rarely used in analog design. also, many if not most has wmin, wmax , lmin, lmax for the model parameter fitting...
  13. #13
    Full Member level 3
    Points: 2,103, Level: 10
    Join Date
    Oct 2004
    Posts
    174
    Points
    2,103
    Level
    10
    the length of a typical transistor.
