Different interpretation of SystemVerilog (involves cast, shift, negation)
likewise
Newbie level 5
I have a simulator and a synthesize tool which have conflicting results in the following code / case:
lessthan = ((B << 1) <= B_t'(-N));
lessthan is "logic"
N is "logic [11:0]" and has value 53;
B is "logic signed [18:0]" and has value -26;
B_t is a typedef for "logic signed [18:0]";
The simulated design results in lessthan being 0 / false.
The synthesized design results in lessthan being 1 / true.
Which tool is right? In other words, how should the SystemVerilog be interpreted.
- There is a negation of an unsigned logic value 53, followed by a cast to logic signed, on the right hand side of the equation.
- The left hand side has a shift-left by 1, on an logic signed value -26. I expect this to result in -52.
I think B_t'(-N))) is interpreted differently by the two tools.
What is the correct interpretation? Preferably with reference to the SystemVerilog standard.
Thanks for any insight.
It would help instead of writing
lessthan is "logic"
you could write the same in legal SystemVerilog syntax
   logic lessthan;
   logic [11:0] N;
   typedef logic signed [18:0] B_t;
   B_t B;
   initial begin
      N = 53;
      B = -26;
      BB = -N;
      lessthan = ((B <<< 1) <= B_t'(-N));
IEEE 1800-2012 LRM said:
If the expression is assignment compatible with the casting type, then the cast shall return the value that a variable of the casting type would hold after being assigned the expression.
That means
should behave the same as
B_t temp;
temp = -N;
lessthan = ((B <<< 1) <= temp);
That should result in false.
