Question about a case statement in VHDL source code
JK666
Newbie level 1
VHDL
I have a VHDL question.Who can help me resolve this question?
I will appreciate you.Thank you.
For the following VHDL source code, with regards to the “when others” clause within the case statement, answer the following:
1a. For simulation of this model, is the “au_ result <= a + b” operation the best strategy? Explain?
1b. For synthesis of this model, is the “au_ result <= a + b” operation the best strategy? Explain?
library ieee;
use ieee. std_ logic_ 1164.all;
use ieee. numeric_ std. all;
entity au32 is
port (
a : in unsigned (31 downto 0); -- Operand A
b : in unsigned (31 downto 0); -- Operand B
opcode : in unsigned (1 downto 0); -- Opcode
au_ result : out unsigned (31 downto 0) -- arithmetic unit result
end entity au32;
architecture rtl of au32 is
begin
au32_ proc:
process( a, b, opcode) is
begin
case opcode is
when "00" => au_ result <= a + b;
when "01" => au_ result <= a - b;
when "10" => au_ result <= a + 1;
when "11" => au_ result <= b + 1;
when others => au_ result <= a + b;
end case;
end process;
end architecture;
Re: VHDL
For when others case you really need not have any assignment as you have accounted for all possible valid cases for a two bit signal. you can just mention "null" or "X's" there. this models the hardware correctly and also give proper behavior for simulation, since you dont actually want addition to be done when you dont have a proper value on your opcode, right.
keep in mind that simulation behavior should match expected hardware behavior but in this case "when others" case wont actually occur in hardware, so you model it to give you some indication of error in your forcing values to the opcode input.
hope this helps.
