ZC702 (Zynq 7000) Interrupt Programming
saur
Member level 2
I'm using ZC702 board by Xilinx, which uses Zynq 7000 SoC.
Its TRM says, the CAN0 interrupt is connected to GIC which then sends the interrupt signal to the processor (Cortex A9).
I tried to enable the interrupt by programming in Xilinx SDK, but it is not working. When I check the hardware in Xilinx XPS, it says no interrupts are connected in GIC.
How can I connect the interrupt in the Xilinx XPS?
Anyone who has worked on it or knows about it, please help...
Thanks
Saurabh
