jayanthyk192
Full Member level 3
I just built an AVR ISP programmer. I got it working and wrote a program on an ATMEGA128. I'm running this microcontroller off an SMPS(from an old comp.) I switched off the SMPS and after a few minutes switched ON the power. This rendered the USBISP to not work. Then i reconnected the USBISP and again it worked. Then I restarted the SMPS and again I had the same problem. I Tried this many times and had the same problem. What might be the problem? Please help.
Thank you.
Thank you.
