connect capacitive power supply in paralle with a 220V load
yassin.kraouch
Advanced Member level 2
what will be the voltage on the L line, if i connect in parallel a 5V capacitive power supply ?
i am confused because V5V0 should be 5v, and how about L line ? i will connect a 220V load, and i am worried if the L will be also 5V,
many thanks
This NOT the way to do it. The 5V will be sitting at 220V AC and will be lethal. Turn the circuit upside down with the series R and C in the live feed. The neutral will then be the 0V for your 5V, do not connect anything to true earth. If you do, any small voltage on the neutral, from the neutral current flowing ANYWHERE will try to go down your earth connection, so currents in the order of 10s of amps could be expected through this connection.
Frank
yes but nodody knows if he will really connect the L to line and N to neutral,
Adding the capacitive supply will make no difference to the voltage on the L line.
FWIW, I agree with everything Frank said.
the problem is that i connected a 220V load in parallel and it works well, so the voltage is not %v, right ?
