[SOLVED] How to code for DS1307 RTC using pic18f87k22
dhakeparag81
Full Member level 2
INDIA
Hello there,
I am working on RTC Ds1307 using pic18f87k22 controller from few days but i dont know where i go wrong.
I search most of the website but didnt get the solution.
Here i post my code can you please trace out where are the problems.
#include<p18f87k22.h>
#include<i2c.h>
void delay(void);
signed char ack=0;
unsigned char sec=0,min=0,hr=0,day=0,date=0,month=0,year=0;
unsigned char temp=0,temp1=0,temp2=0,i=0;
#pragma interrupt chk_isr         // used for high priority interrupt only.
void chk_isr()
	if(PIR1bits.SSP1IF == 1)
	    PIR1bits.SSP1IF=0;
#pragma code HI_PRIO_INT=0x0008      // high priority interrupt location.
void HI_PRIO_INT(void)
  _asm
  goto chk_isr
 _endasm
#pragma code
void main(void)
	OSCTUNE = 0X80;			//	0xc0 for internal oscillator pll enabled
    OSCCON=0X74;             //16MHz
    OSCCON2=0X00;
	ANCON0=0x00;                   // make all analog channel as digital I/O.
    ANCON1=0x00;                   // make all analog channel as digital I/O.
    ANCON2=0x00;
    ODCON1=0x00;
    ODCON2=0x00;
    PADCFG1=0x20;
    CM1CON=0x00;                    // comparator1 OFF.
    CM2CON=0x00;                    // comparator2 OFF.
    CM3CON=0x00;                    // comparator3 OFF.
    MEMCONbits.EBDIS=1;
    ADCON0=0x00;                   // make all analog channel as digital I/O.
    TRISCbits.TRISC3=1;
    TRISCbits.TRISC4=1;
    OpenI2C1(MASTER,SLEW_OFF);
    //SSP1CON1=0x2b;
     SSP2CON2=0x080;
    SSP1ADD=0x27;	//for 100khz
    IdleI2C1();
   StartI2C1();
   ack=WriteI2C1(0xD0);
   delay();
   ack=WriteI2C1(0x00);//add
   ack=WriteI2C1(0x05);
   ack=WriteI2C1(0x72);
   ack=WriteI2C1(0x03);
   ack=WriteI2C1(0x11);
   ack=WriteI2C1(0x02);
   ack=WriteI2C1(0x14);
   StopI2C1();
  delay();
  delay();
    while(1)
	    IdleI2C1();
	     StartI2C1();
   		delay();
	//    StartI2C1();
	    delay();
	    delay();
	    ack=WriteI2C1(0xD1);
	    delay();
	    delay();
	    sec=ReadI2C1();
	    AckI2C1();
	   delay();
	    temp=0;
	    temp1=0;
	    temp2=0x80;
	    for(i=7;i>0;i=i-2)
		    temp1 = sec & temp2;
		    temp |= (temp1>>i);
		    temp2 >>=1;
		    if(i==1)
		    i=2;
		    //i=i-2;
		 for(i=1;i<8;i=i+2)
		    temp |= (temp1<<i);
		    temp2 >>=1;
		    //i=i+2;
	    sec=temp;
	     delay();
	     min=ReadI2C1();
	   AckI2C1();
	    delay();
	    /* temp=0;
	    temp1=0;
	    temp2=0x80;
	    for(i=7;i>0;i=i-2)
		    temp1 = min & temp2;
		    temp |= (temp1>>i);
		    temp2 >>=1;
		    if(i==1)
		    i=2;
		    //i=i-2;
		 for(i=1;i<8;i=i+2)
		    temp |= (temp1<<i);
		    temp2 >>=1;
		    //i=i+2;
	    min=temp;
	    delay();
	    hr=ReadI2C1();
	 AckI2C1();
	    delay();
	     temp=0;
	    temp1=0;
	    temp2=0x80;
	    for(i=7;i>0;i=i-2)
		    temp1 = hr & temp2;
		    temp |= (temp1>>i);
		    temp2 >>=1;
		    if(i==1)
		    i=2;
		    //i=i-2;
		 for(i=1;i<8;i=i+2)
		    temp1 = hr & temp2;
		    temp |= (temp1<<i);
		    temp2 >>=1;
		    //i=i+2;
	 hr=temp;
	    delay();
	    day=ReadI2C1();
	    AckI2C1();
	    delay();
	    temp=0;
	    temp1=0;
	    temp2=0x80;
	    for(i=7;i>0;i=i-2)
		    temp1 = day & temp2;
		    temp |= (temp1>>i);
		    temp2 >>=1;
		    if(i==1)
		    i=2;
		    //i=i-2;
		 for(i=1;i<8;i=i+2)
		    temp |= (temp1<<i);
		    temp2 >>=1;
		    //i=i+2;
		  day=temp;
	        delay();
	    date=ReadI2C1();
	    AckI2C1();
	     delay();
	    temp=0;
	    temp1=0;
	    temp2=0x80;
	    for(i=7;i>0;i=i-2)
		    temp1 = date & temp2;
		    temp |= (temp1>>i);
		    temp2 >>=1;
		    if(i==1)
		    i=2;
		    //i=i-2;
		 for(i=1;i<8;i=i+2)
		    temp |= (temp1<<i);
		    temp2 >>=1;
		    //i=i+2;
	    date=temp;
	        delay();
	    month=ReadI2C1();
	    AckI2C1();
	    delay();
	   /* temp=0;
	    temp1=0;
	    temp2=0x80;
	    for(i=7;i>0;i=i-2)
		    temp1 = month & temp2;
		    temp |= (temp1>>i);
		    temp2 >>=1;
		    if(i==1)
		    i=2;
		    //i=i-2;
		 for(i=1;i<8;i=i+2)
		    temp |= (temp1<<i);
		    temp2 >>=1;
		    //i=i+2;
	    month=temp;
	      delay();
	    year=ReadI2C1();
	     NotAckI2C1();
	     delay();
	    temp=0;
	    temp1=0;
	    temp2=0x80;
	    for(i=7;i>0;i=i-2)
		    temp1 = year & temp2;
		    temp |= (temp1>>i);
		    temp2 >>=1;
		    if(i==1)
		    i=2;
		    //i=i-2;
		 for(i=1;i<8;i=i+2)
		    temp |= (temp1<<i);
		    temp2 >>=1;
		    //i=i+2;
	    year=temp;
	 delay();
	 delay();
void delay(void)
	unsigned int t=0;
	for(t=0;t<250;t++);
I used the internal library of mplabc18 compiler.
This is the code I used to interface DS1307 with PIC18F45K22(4MHz Crystal). You can refer this and make the necessary modifications. Change I2C2 to I2C1.
#include <delays.h>
#include <i2c.h>
#include <stdlib.h>
unsigned char sec, min, hr, week_day, day, mn, year;
unsigned char last_date;
char tnum[4],txt;
void readDS1307(char *sec, char *min, char *hr, char *week_day, char *day, char *mn, char *year)
	StartI2C2();
    	WriteI2C2(0xD0);
	WriteI2C2(0x00);
	RestartI2C2();
	WriteI2C2(0xD1);
       *sec = ReadI2C2();
	AckI2C2();
	*min = ReadI2C2();
   	AckI2C2();
	*hr = ReadI2C2();
 	AckI2C2();
	*week_day = ReadI2C2();
 	AckI2C2();
	*day = ReadI2C2();
 	AckI2C2();
	*mn = ReadI2C2();
 	AckI2C2();
	*year = ReadI2C2();
	NotAckI2C2();
	StopI2C2();
void writeDS1307()
    StartI2C2();
	WriteI2C2(0xD0);
	WriteI2C2(0x00);
	WriteI2C2(0x00);// sec
	WriteI2C2(0x01);//minutes
	WriteI2C2(0x01);// hours
	WriteI2C2(0x01);//week_day
	WriteI2C2(0x15);//date
    WriteI2C2(0x12);//month
	WriteI2C2(0x13);//year
	WriteI2C2(0x10);   // REG 7 - Enable squarewave output pin1hz
	StopI2C2();
// -------------------- Formats date and time
void Transform_Time(char *sec, char *min, char *hr, char *week_day, char *day, char *mn, char *year)
*sec = ((*sec & 0x70) >> 4)*10 + (*sec & 0x0F);
*min = ((*min & 0x70) >> 4)*10 + (*min & 0x0F);
*hr =  ((*hr  & 0x30) >> 4)*10 + (*hr & 0x0F);
*week_day =(*week_day & 0x07);
*day = ((*day  & 0x30) >> 4)*10 + (*day  & 0x0F);
*mn =  ((*mn   & 0x70) >> 4)*10 + (*mn   & 0x0F);
*year =((*year & 0xF0) >> 4)*10 + (*year & 0x0F);
void __init(void){
    ANSELA = 0;
    ANSELB = 0;
    ANSELD = 0;
    ANSELC = 0;
    ANSELE = 0;
    ADCON0 = 0;
    OpenI2C2(MASTER,SLEW_OFF);
    Delay10KTCYx(25);
    SSP2ADD=39;  //set i2c clock
    StartI2C2();
    IdleI2C2();
    Delay10KTCYx(25);
   //  writeDS1307();
void main(void)
   __init();
    while(1){
    readDS1307(&sec, &min, &hr, &week_day, &day, &mn, &year);
    Transform_Time(&sec, &min, &hr, &week_day, &day, &mn, &year);
    Delay10KTCYx(25);
Refer this link:
https://www.edaboard.com/threads/305029/
Try with changing
SSPCON1 = 38;
Note:
I think This PIC itself has RTC
Thank you for u r time,
The code posted by ADGN working for me.
I made several changes which are require for my controller.
I also change the DS1307 then i able to read the values, may be IC was damage.
But at first i received some random number due to that i am not considering to change DS1307.
Hello PA3040,
Yes this pic have the RTC but to keep it up to date i have to power (BAT) whole CPU which drain the battery rapidly
instead i prefer to use external RTC and supply battery only to the RTC i think it is more efficient.
