[PIC] How to convert the ADC 10 bit Hex result to ASCII value
ecaits
Member level 4
How can I convert the result of 10 bit hex ADC to ASCII in pic16F877 using hi-tech c compiler???
I mean how many methods or logics are there????
You can't.
ASCII is 8 bits.
Do you want to create a 2-byte ASCII representation of your 10-bit number?
It is relatively easy.
10bit -> 0000 - 1023
Numers - ASCII
0dec - 30hex (48dec)
1dec - 31hex (49dec)
9dec - 39hex (57dec)
This mean that number you get from ADC e.g. 0876, you have to split to numbers 0 - 8 - 7 - 6 and then your ASCII message will be 30h - 38h - 37h - 36h (or in decade number format 48 - 56 - 55 - 54)
See more about ascii table on: https://en.wikipedia.org/wiki/ASCII
Best regards,
Mr.Cube
