Black level of component video signal ( YPrPb, YCrCb )?
spktu
Member level 5
black level in video signal
Is there a standard defining the black level of component video signals ( YPrPb, YCrCb )?
Should it be 0V for each three of them or 1-2 V is also acceptable?
Component (YCrCb) Y - 1vpp
Cr – 700mv pp
Cb – 700mv pp
SDTV Cr=0.713(R-Y), Cb= .564(B-Y) For black, grey or white both signals are +350 mV For the strongest colours a maximum of 350 mV will be added or subtracted depending on the colour.
HDTV Pr=.6349(R-Y), Pb=.5389(B-Y) For black, grey or white both signals are +350 mV For the strongest colours a maximum of 350 mV will be added or subtracted depending on the colour.
I asked about "black level" voltage a the front po
I asked about "black level" voltage a the front porch, not peak-to-peak voltages!
Hi
see EIA-770.2 "Standard Definition TV Analog Component Video Interface"
ynhe
Generally this level does not matter, since most video inputs are AC coupled, followed by a DC restoration circuit. So under these circumstances, even with 1-2VDC measured at the video output, things should be OK.
If it's ADC input , that should have clamping circuit.
and we can set clamping position.
