+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 1
    Points: 1,239, Level: 7
    Join Date
    Jan 2014
    Posts
    104
    Points
    1,239
    Level
    7
    Difference of forward voltage and Bias voltage source
    what's the difference between the forward voltage and Bias voltage source.
    I'm confuse with the functions of these voltages. especially when i look at them in the V-I characteristic of Diode.
    •   Alt17th January 2014, 14:46
      advertising
  2. #2
    Full Member level 4
    Points: 1,153, Level: 7
    Join Date
    Nov 2013
    Vermont, USA
    Posts
    191
    Points
    1,153
    Level
    7
    Re: Difference of forward voltage and Bias voltage source
    The term "bias" is very general and describes a stable operating point in a circuit. Often for a diode, it refers to a "reverse" voltage where the diode is "off" and not conducting. So, for a diode, the forward voltage is the voltage across the diode when it is "on" and conducting normally. It is the region in the upper right quadrant of the IV curve. A bias voltage is a voltage across the diode when it is "off" and not conducting. It is the region in the lower left quadrant of the IV curve. Another way to think of a diode bias voltage is a "reverse" voltage. So, there are forward and reverse voltage. A "Bias voltage source" for a diode would be a voltage source which puts a stable, reverse voltage on the diode.
    One use of reverse biasing a diode with a voltage source is in clamp circuits which provide overvoltage protection. Normally, the diode is off. However, if a signal voltage on the other side of the diode exceeds the bias voltage plus the diode forward voltage drop, the diode turns on and limits the signal voltage. Also, photo-diodes are reversed biased to enhanced their light response.
