uttarawakhle
Newbie level 2
i am a newbie in PIC and Assembly language. i am trying to compile the code. but it alwyas show error of section .org_0 cannot fit in absolute section.
If anyone can help me in this i would be grateful.
I am unable to remove this error.
Please help..
Thanks in anticipation
Uttara
i am attaching my code here and also the output
Please help..
Uttara
#include <p18cxxx.inc>
#include "devices.inc"
#include "bootconfig.inc"
#include "preprocess.inc"
#define STX 0x0F
#define ETX 0x04
#define DLE 0x05
#define NTX 0xFF
; RAM Address Map
CRCL equ 0x00
CRCH equ 0x01
RXDATA equ 0x02
TXDATA equ 0x03
; Framed Packet Format
; <STX>[<COMMAND><ADDRL><ADDRH><ADDRU><0x00><DATALEN><...DATA...>]<CRCL><CRCH><ETX>
COMMAND equ 0x05 ; receive buffer
ADDRESS_L equ 0x06
ADDRESS_H equ 0x07
ADDRESS_U equ 0x08
ADDRESS_X equ 0x09
DATA_COUNTL equ 0x0A
PACKET_DATA equ 0x0B
DATA_COUNTH equ 0x0B ; only for certain commands
errorlevel -311 ; don't warn on HIGH() operator values >16-bits
#ifdef USE_SOFTBOOTWP
#ifndef SOFTWP
#define SOFTWP
#endif
#endif
#ifdef USE_SOFTCONFIGWP
#ifdef CONFIG_AS_FLASH
#ifndef SOFTWP
#define SOFTWP
#endif
#endif
#endif
#ifndef AppVector
; The application startup GOTO instruction will be written just before the Boot Block,
; courtesy of the host PC bootloader application.
#define AppVector (BootloaderStart-.4)
#endif
#if BOOTLOADER_ADDRESS != 0
ORG 0
; The following GOTO is not strictly necessary, but may startup faster
; for large microcontrollers running at extremely slow clock speeds.
;goto BootloaderBreakCheck
ORG BOOTLOADER_ADDRESS
BootloaderStart:
bra BootloadMode
; Determine if the application is supposed to be started or if we should
; go into bootloader mode.
; If RX pin is in BREAK state when we come out of MCLR reset, immediately
; enter bootloader mode, even if there exists some application firmware in
; program memory.
BootloaderBreakCheck:
DigitalInput ; set RX pin as digital input on certain parts
#ifdef INVERT_UART
btfss RXPORT, RXPIN
GotoAppVector:
goto AppVector ; no BREAK state, attempt to start application
#else
btfsc RXPORT, RXPIN
GotoAppVector:
#endif
BootloadMode:
#else ; BOOTLOADER_ADDRESS == 0 ****************************************************************
ORG 0
BootloaderStart:
movlw low(AppVector) ; load address of application reset vector
bra BootloaderBreakCheck
ORG 0x0008
HighPriorityInterruptVector:
goto AppHighIntVector ; Re-map Interrupt vector
#ifdef INVERT_UART
btfsc RXPORT, RXPIN
bra BootloadMode
#else
btfss RXPORT, RXPIN
bra BootloadMode
#endif
CheckAppVector:
; Read instruction at the application reset vector location.
; If we read 0xFFFF, assume that the application firmware has
; not been programmed yet, so don't try going into application mode.
movwf TBLPTRL
movlw high(AppVector)
movwf TBLPTRH
bra CheckAppVector2
ORG 0x0018
LowPriorityInterruptVector:
goto AppLowIntVector ; Re-map Interrupt vector
CheckAppVector2:
movlw upper(AppVector)
movwf TBLPTRU
tblrd *+ ; read instruction from program memory
incfsz TABLAT, W ; if the lower byte != 0xFF,
GotoAppVector:
goto AppVector ; run application.
incfsz TABLAT, W ; if the lower byte == 0xFF but upper byte != 0xFF,
bra GotoAppVector ; run application.
; otherwise, assume application firmware is not present because we read a NOP (0xFFFF).
; fall through to bootloader mode...
BootloadMode:
#endif ; end BOOTLOADER_ADDRESS == 0 ******************************************
lfsr FSR2, 0 ; for compatibility with Extended Instructions mode.
#ifdef USE_MAX_INTOSC
movlw b'01110000' ; set INTOSC to maximum speed (usually 8MHz)
iorwf OSCCON, f
#endif
#ifdef USE_PLL
#ifdef PLLEN
#ifdef OSCTUNE
bsf OSCTUNE, PLLEN ; enable PLL for faster internal clock
#else
; 18F8680, 18F8585, 18F6680, and 18F6585 doesn't have OSCTUNE register.
; Instead, PLLEN bit is in OSCCON.
bsf OSCCON, PLLEN ; enable PLL for faster internal clock
#endif
#else
#ifdef SPLLEN
bsf OSCTUNE, SPLLEN ; PIC18F14K50 has SPLLEN at bit 6
#endif
#endif
#endif
#ifdef INVERT_UART
btfsc RXPORT, RXPIN ; wait for RX pin to go IDLE
bra $-2
#else
btfss RXPORT, RXPIN ; wait for RX pin to go IDLE
bra $-2
#endif
#ifdef PPS_UTX_PIN
banksel PPSCON
; unlock PPS registers
movlw 0x55
movwf EECON2, ACCESS
movlw 0xAA
bcf PPSCON, IOLOCK, BANKED
; assign UART RX/TX to PPS remappable pins
movlw PPS_UTX
movwf PPS_UTX_PIN, BANKED
movlw PPS_URX_PIN
movwf PPS_URX, BANKED
; lock PPS registers from inadvertent changes
movlw 0x55
movlw 0xAA
bsf PPSCON, IOLOCK, BANKED
movlb 0x0F
#endif
movlw b'10010000' ; Setup UART
movwf UxRCSTA
movlw b'00100110' ; BRGH = 1, TXEN = 1
movwf UxTXSTA
#ifdef INVERT_UART
bsf UxBAUDCON, RXDTP
bsf UxBAUDCON, TXCKP
#endif
#ifdef BRG16
bsf UxBAUDCON, BRG16
movlw b'00000010' ; 1:8 prescaler - no division required later (but no rounding possible)
#else
movlw b'00000011' ; 1:16 prescaler - thus we only have to divide by 2 later on.
#endif
movwf T0CON
#ifdef PICDEM_LCD2
bsf LATB, LATB0 ; PICDEM LCD 2 demoboard requires RB0 high to enable MAX3221 TX output to PC.
bcf TRISB, TRISB0
#endif
#ifdef USE_AUTOBAUD
DoAutoBaud:
; ___ __________ ________
; \__/ \__________/
; |-------- p ----------|
; p = The number of instructions between the first and last
; rising edge of the RS232 control sequence 0x0F. Other
; possible control sequences are 0x01, 0x03, 0x07, 0x1F,
; 0x3F, 0x7F.
; SPBRG = (p / 32) - 1 BRGH = 1, BRG16 = 0
; SPBRG = (p / 8) - 1 BRGH = 1, BRG16 = 1
bcf UxRCSTA, CREN ; Stop receiving
movf UxRCREG, W ; Empty the buffer
movf UxRCREG, W
RetryAutoBaud:
clrf TMR0H ; reset timer count value
clrf TMR0L
bcf INTCON, TMR0IF
rcall WaitForRise ; wait for a start bit to pass by
bsf T0CON, TMR0ON ; start timer counting for entire D7..D0 data bit period.
rcall WaitForRise ; wait for stop bit
bcf T0CON, TMR0ON ; stop the timer from counting further.
btfsc INTCON, TMR0IF ; if TMR0 overflowed, we did not get a good baud capture
bra RetryAutoBaud ; try again
#ifdef BRG16
; save new baud rate generator value
movff TMR0L, UxSPBRG ; warning: must read TMR0L before TMR0H holds real data
movff TMR0H, UxSPBRGH
#else
; TMR0H:TMR0L holds (p / 16).
rrcf TMR0H, w ; divide by 2
rrcf UxSPBRG, F
btfss STATUS, C ; rounding
decf UxSPBRG, F
#endif
bsf UxRCSTA, CREN ; start receiving
WaitForHostCommand:
rcall ReadHostByte ; get start of transmission <STX>
xorlw STX
bnz DoAutoBaud ; got something unexpected, perform autobaud
#else ; not using autobaud
movlw low(BAUDRG) ; set fixed baud rate generator value
movwf UxSPBRG
#ifdef UxSPBRGH
#if high(BAUDRG) != 0
movlw high(BAUDRG)
movwf UxSPBRGH
#endif
#endif
DoAutoBaud:
WaitForHostCommand:
xorlw STX
bnz WaitForHostCommand ; got something unexpected, keep waiting for <STX>
#endif ; end #ifdef USE_AUTOBAUD
; Read and parse packet data.
StartOfLine:
movlw STX ; send back start of response
rcall SendHostByte
lfsr FSR0, COMMAND-1 ; Point to the buffer
ReceiveDataLoop:
rcall ReadHostByte ; Get the data
xorlw STX ; Check for an unexpected STX
bz StartOfLine ; unexpected STX: abort packet and start over.
NoSTX:
movf RXDATA, W
xorlw ETX ; Check for a ETX
bz VerifyPacketCRC ; Yes, verify CRC
NoETX:
movf RXDATA, W
xorlw DLE ; Check for a DLE
bnz AppendDataBuffer
rcall ReadHostByte ; DLE received, get the next byte and store it
AppendDataBuffer:
movff RXDATA, PREINC0 ; store the data to the buffer
bra ReceiveDataLoop
VerifyPacketCRC:
lfsr FSR1, COMMAND
clrf CRCL
clrf CRCH
movff POSTDEC0, PRODH ; Save host packet's CRCH to PRODH for later comparison
; CRCL is now available as INDF0
VerifyPacketCrcLoop:
movf POSTINC1, w
rcall AddCrc ; add new data to the CRC
movf FSR1H, w
cpfseq FSR0H
bra VerifyPacketCrcLoop ; we aren't at the end of the received data yet, loop
movf FSR1L, w
cpfseq FSR0L
movf CRCH, w
cpfseq PRODH
bra DoAutoBaud ; invalid CRC, reset baud rate generator to re-sync with host
movf CRCL, w
cpfseq INDF0
; Pre-setup, common to all commands.
clrf CRCL
clrf CRCH
movf ADDRESS_L, W ; Set all possible pointers
movwf TBLPTRL
#ifdef EEADR
movwf EEADR
#endif
movf ADDRESS_H, W
movwf TBLPTRH
#ifdef EEADRH
movwf EEADRH
#endif
movff ADDRESS_U, TBLPTRU
lfsr FSR0, PACKET_DATA
; Test the command field and sub-command.
CheckCommand:
movlw .10
cpfslt COMMAND
bra DoAutoBaud ; invalid command - reset baud generator to re-sync with host
; This jump table must exist entirely within one 256 byte block of program memory.
;#if (($ & 0xFF) > (0xFF - .24))
; Too close to the end of a 256 byte boundary, push address forward to get code
; into the next 256 byte block.
; messg "Wasting some code space to ensure jump table is aligned."
; ORG $+(0x100 - ($ & 0xFF))
;#endif
JUMPTABLE_BEGIN:
movf PCL, w ; 0 do a read of PCL to set PCLATU:PCLATH to current program counter.
rlncf COMMAND, W ; 2 multiply COMMAND by 2 (each BRA instruction takes 2 bytes on PIC18)
addwf PCL, F ; 4 Jump in command jump table based on COMMAND from host
bra BootloaderInfo ; 6 00h
bra ReadFlash ; 8 01h
bra VerifyFlash ; 10 02h
bra EraseFlash ; 12 03h
bra WriteFlash ; 14 04h
bra ReadEeprom ; 16 05h
bra WriteEeprom ; 18 06h
bra WriteConfig ; 20 07h
bra GotoAppVector ; 22 08h
reset ; 24 09h
;#if (JUMPTABLE_BEGIN & 0xFF) > ($ & 0xFF)
; error "Jump table is not aligned to fit within a single 256 byte address range."
;#endif
#ifdef INVERT_UART
WaitForRise:
clrwdt
WaitForRiseLoop:
return ; abort
btfss RXPORT, RXPIN ; Wait for a falling edge
bra WaitForRiseLoop
WtSR:
btfsc RXPORT, RXPIN ; Wait for starting edge
bra WtSR
return
#else ; not inverted UART pins
WaitForRise:
clrwdt
WaitForRiseLoop
return ; abort
btfsc RXPORT, RXPIN ; Wait for a falling edge
bra WaitForRiseLoop
WtSR:
btfss RXPORT, RXPIN ; Wait for rising edge
bra WtSR
return
#endif ; end #ifdef INVERT_UART
; 16-bit CCITT CRC
; Adds WREG byte to the CRC checksum CRCH:CRCL. WREG destroyed on return.
AddCrc: ; Init: CRCH = HHHH hhhh, CRCL = LLLL llll
xorwf CRCH, w ; Pre: HHHH hhhh WREG = IIII iiii
movff CRCL, CRCH ; Pre: LLLL llll CRCH = LLLL llll
movwf CRCL ; Pre: IIII iiii CRCL = IIII iiii
swapf WREG ; Pre: IIII iiii WREG = iiii IIII
andlw 0x0F ; Pre: iiii IIII WREG = 0000 IIII
xorwf CRCL, f ; Pre: IIII iiii CRCL = IIII jjjj
swapf CRCL, w ; Pre: IIII jjjj WREG = jjjj IIII
andlw 0xF0 ; Pre: jjjj IIII WREG = jjjj 0000
xorwf CRCH, f ; Pre: LLLL llll CRCH = MMMM llll
rlncf WREG, w ; Pre: jjjj IIII WREG = jjjI IIIj
xorwf CRCH, f ; Pre: MMMM llll CRCH = XXXN mmmm
andlw b'11100000' ; Pre: jjjI IIIj WREG = jjj0 0000
xorwf CRCH, f ; Pre: jjj0 0000 CRCH = MMMN mmmm
xorwf CRCL, f ; Pre: MMMN mmmm CRCL = JJJI jjjj
return
; Commands
; Provides information about the Bootloader to the host PC software.
BootInfoBlock:
db low(BOOTBLOCKSIZE), high(BOOTBLOCKSIZE)
db MAJOR_VERSION, MINOR_VERSION
db 0xFF, 0x84 ; command mask : family id
db low(BootloaderStart), high(BootloaderStart)
db upper(BootloaderStart), 0
BootInfoBlockEnd:
; In: <STX>[<0x00>]<CRCL><CRCH><ETX>
; Out: <STX><BOOTBYTESL><BOOTBYTESH><VERL><VERH><STARTBOOTL><STARTBOOTH><STARTBOOTU><0x00><CRCL><CRCH><ETX>
BootloaderInfo:
movlw low(BootInfoBlock)
movwf TBLPTRL
movlw high(BootInfoBlock)
movwf TBLPTRH
movlw upper(BootInfoBlock)
movwf TBLPTRU
movlw (BootInfoBlockEnd - BootInfoBlock)
movwf DATA_COUNTL
clrf DATA_COUNTH
;; fall through to ReadFlash code -- send Bootloader Information Block from FLASH.
; In: <STX>[<0x01><ADDRL><ADDRH><ADDRU><0x00><BYTESL><BYTESH>]<CRCL><CRCH><ETX>
; Out: <STX>[<DATA>...]<CRCL><CRCH><ETX>
ReadFlash:
tblrd *+ ; read from FLASH memory into TABLAT
movf TABLAT, w
rcall SendEscapeByte
rcall AddCrc
decf DATA_COUNTL, f ; decrement counter
movlw 0
subwfb DATA_COUNTH, f
movf DATA_COUNTL, w ; DATA_COUNTH:DATA_COUNTH == 0?
iorwf DATA_COUNTH, w
bnz ReadFlash ; no, loop
bra SendChecksum ; yes, send end of packet
; In: <STX>[<0x02><ADDRL><ADDRH><ADDRU><0x00><BLOCKSL><BLOCKSH>]<CRCL><CRCH><ETX>
; Out: <STX>[<CRCL1><CRCH1>...<CRCLn><CRCHn>]<ETX>
VerifyFlash:
tblrd *+
movf TABLAT, w
rcall AddCrc
movf TBLPTRL, w ; have we crossed into the next block?
#if ERASE_FLASH_BLOCKSIZE > .255
bnz VerifyFlash
movf TBLPTRH, w
andlw high(ERASE_FLASH_BLOCKSIZE-1)
#else
andlw (ERASE_FLASH_BLOCKSIZE-1)
#endif
bnz VerifyFlash
movf CRCL, w
call SendEscapeByte
movf CRCH, w
call SendEscapeByte
movlw 0
bnz VerifyFlash ; no, loop
bra SendETX ; yes, send end of packet
#ifdef SOFTWP
reset ; this code -should- never be executed, but
reset ; just in case of errant execution or buggy
reset ; firmware, these reset instructions may protect
reset ; against accidental erases.
#endif
; In: <STX>[<0x03><ADDRL><ADDRH><ADDRU><0x00><PAGESL>]<CRCL><CRCH><ETX>
; Out: <STX>[<0x03>]<CRCL><CRCH><ETX>
EraseFlash:
#ifdef SOFTWP
#define ERASE_ADDRESS_MASK (~(ERASE_FLASH_BLOCKSIZE-1))
#if upper(ERASE_ADDRESS_MASK) != 0xFF
movlw upper(ERASE_ADDRESS_MASK) ; force starting address to land on a FLASH Erase Block boundary
andwf TBLPTRU, f
#endif
#if high(ERASE_ADDRESS_MASK) != 0xFF
movlw high(ERASE_ADDRESS_MASK) ; force starting address to land on a FLASH Erase Block boundary
andwf TBLPTRH, f
#endif
#if low(ERASE_ADDRESS_MASK) != 0xFF
movlw low(ERASE_ADDRESS_MASK) ; force starting address to land on a FLASH Erase Block boundary
andwf TBLPTRL, f
#endif
; Verify Erase Address does not attempt to erase beyond the end of FLASH memory
movlw low(END_FLASH)
subwf TBLPTRL, w
movlw high(END_FLASH)
subwfb TBLPTRH, w
movlw upper(END_FLASH)
subwfb TBLPTRU, w
bn EraseEndFlashAddressOkay
clrf EECON1 ; inhibit writes for this block
bra NextEraseBlock ; move on to next erase block
#endif ; end #ifdef USE_SOFTBOOTWP
EraseEndFlashAddressOkay:
movlw low(END_FLASH - ERASE_FLASH_BLOCKSIZE)
subwf TBLPTRL, w
movlw high(END_FLASH - ERASE_FLASH_BLOCKSIZE)
subwfb TBLPTRH, w
movlw upper(END_FLASH - ERASE_FLASH_BLOCKSIZE)
subwfb TBLPTRU, w
bn EraseConfigAddressOkay
EraseConfigAddressOkay:
#endif ; end CONFIG_AS_FLASH
#endif ; end USE_SOFTCONFIGWP
movlw low(BOOTLOADER_ADDRESS)
subwf TBLPTRL, w
movlw high(BOOTLOADER_ADDRESS)
subwfb TBLPTRH, w
movlw upper(BOOTLOADER_ADDRESS)
subwfb TBLPTRU, w
bn EraseAddressOkay
movlw low(BOOTLOADER_ADDRESS + BOOTBLOCKSIZE)
subwf TBLPTRL, w
movlw high(BOOTLOADER_ADDRESS + BOOTBLOCKSIZE)
subwfb TBLPTRH, w
movlw upper(BOOTLOADER_ADDRESS + BOOTBLOCKSIZE)
subwfb TBLPTRU, w
bnn EraseAddressOkay
reset ; firmware, these reset instruction may protect
reset ; against accidental writes.
#endif
EraseAddressOkay:
#ifdef EEADR
movlw b'10010100' ; setup FLASH erase
#else
movlw b'00010100' ; setup FLASH erase for J device (no EEPROM bit)
#endif
movwf EECON1
rcall StartWrite ; erase the page
NextEraseBlock:
; Decrement address by erase block size
#if ERASE_FLASH_BLOCKSIZE >= .256
movlw high(ERASE_FLASH_BLOCKSIZE)
subwf TBLPTRH, F
clrf WREG
subwfb TBLPTRU, F
#else
movlw ERASE_FLASH_BLOCKSIZE
subwf TBLPTRL, F
clrf WREG
subwfb TBLPTRH, F
subwfb TBLPTRU, F
#endif
decfsz DATA_COUNTL, F
bra EraseFlash
bra SendAcknowledge ; All done, send acknowledgement packet
#ifdef SOFTWP
#endif
; In: <STX>[<0x04><ADDRL><ADDRH><ADDRU><0x00><BLOCKSL><DATA>...]<CRCL><CRCH><ETX>
; Out: <STX>[<0x04>]<CRCL><CRCH><ETX>
WriteFlash:
#ifdef SOFTWP
#define WRITE_ADDRESS_MASK (~(WRITE_FLASH_BLOCKSIZE-1))
#if upper(WRITE_ADDRESS_MASK) != 0xFF
movlw upper(WRITE_ADDRESS_MASK) ; force starting address to land on a FLASH Write Block boundary
andwf TBLPTRU, f
#endif
#if high(WRITE_ADDRESS_MASK) != 0xFF
movlw high(WRITE_ADDRESS_MASK) ; force starting address to land on a FLASH Write Block boundary
andwf TBLPTRH, f
#endif
#if low(WRITE_ADDRESS_MASK) != 0xFF
movlw low(WRITE_ADDRESS_MASK) ; force starting address to land on a FLASH Write Block boundary
andwf TBLPTRL, f
#endif
; Verify Write Address does not attempt to write beyond the end of FLASH memory
subwf TBLPTRL, w
subwfb TBLPTRH, w
subwfb TBLPTRU, w
bn WriteEndFlashAddressOkay
bra LoadHoldingRegisters; fake the write so we can move on to real writes
#endif ; end #ifdef SOFTWP
WriteEndFlashAddressOkay:
subwf TBLPTRL, w
subwfb TBLPTRH, w
subwfb TBLPTRU, w
bn WriteConfigAddressOkay
WriteConfigAddressOkay:
subwf TBLPTRL, w
subwfb TBLPTRH, w
subwfb TBLPTRU, w
bn WriteAddressOkay
subwf TBLPTRL, w
subwfb TBLPTRH, w
subwfb TBLPTRU, w
bnn WriteAddressOkay
bra LoadHoldingRegisters ; fake the write so we can move on to real writes
#endif
WriteAddressOkay:
#ifdef EEADR
movlw b'10000100' ; Setup FLASH writes
#else
movlw b'00000100' ; Setup FLASH writes for J device (no EEPROM bit)
#endif
movwf EECON1
LoadHoldingRegisters:
movff POSTINC0, TABLAT ; Load the holding registers
pmwtpi ; Same as tblwt *+
movf TBLPTRL, w ; have we crossed into the next write block?
andlw (WRITE_FLASH_BLOCKSIZE-1)
bnz LoadHoldingRegisters; Not finished writing holding registers, repeat
tblrd *- ; Point back into the block to write data
rcall StartWrite ; initiate a page write
tblrd *+ ; Restore pointer for loading holding registers with next block
bra WriteFlash ; Not finished writing all blocks, repeat
bra SendAcknowledge ; all done, send ACK packet
; In: <STX>[<0x05><ADDRL><ADDRH><0x00><0x00><BYTESL><BYTESH>]<CRCL><CRCH><ETX>
#ifdef EEADR ; some devices do not have EEPROM, so no need for this code
ReadEeprom:
clrf EECON1
ReadEepromLoop:
bsf EECON1, RD ; Read the data
movf EEDATA, w
#ifdef EEADRH
infsnz EEADR, F ; Adjust EEDATA pointer
incf EEADRH, F
#else
incf EEADR, F ; Adjust EEDATA pointer
#endif
rcall AddCrc
#ifdef EEADRH
movlw 0
bnz ReadEepromLoop ; no, loop
#else
bra ReadEepromLoop ; Not finished then repeat
bra SendChecksum
#endif
#endif ; end #ifdef EEADR
; In: <STX>[<0x06><ADDRL><ADDRH><0x00><0x00><BYTESL><BYTESH><DATA>...]<CRCL><CRCH><ETX>
; Out: <STX>[<0x06>]<CRCL><CRCH><ETX>
WriteEeprom:
movlw b'00000100' ; Setup for EEPROM data writes
movwf EECON1
WriteEepromLoop:
movff PREINC0, EEDATA
rcall StartWrite
btfsc EECON1, WR ; wait for write to complete before moving to next address
bra $-2
#ifdef EEADRH
incf EEADRH, F
#else
incf EEADR, f ; Adjust EEDATA pointer
#endif
#ifdef EEADRH
movlw 0
bnz WriteEepromLoop ; no, loop
bra SendAcknowledge ; yes, send end of packet
#else
decfsz DATA_COUNTL, f
bra WriteEepromLoop
bra SendAcknowledge
#endif
; In: <STX>[<0x07><ADDRL><ADDRH><ADDRU><0x00><BYTES><DATA>...]<CRCL><CRCH><ETX>
; Out: <STX>[<0x07>]<CRCL><CRCH><ETX>
#ifndef CONFIG_AS_FLASH ; J flash devices store config words in FLASH, so no need for this code
#ifndef USE_SOFTCONFIGWP
WriteConfig:
movlw b'11000100'
movwf EECON1
tblrd * ; read existing value from config memory
WriteConfigLoop:
movf POSTINC0, w
cpfseq TABLAT ; is the proposed value already the same as existing value?
rcall TableWriteWREG ; write config memory only if necessary (save time and endurance)
tblrd +* ; increment table pointer to next address and read existing value
bra WriteConfigLoop ; If more data available in packet, keep looping
bra SendAcknowledge ; Send acknowledge
#endif ; end #ifndef USE_SOFTCONFIGWP
#endif ; end #ifndef CONFIG_AS_FLASH
; Send an acknowledgement packet back
; <STX><COMMAND><CRCL><CRCH><ETX>
; Some devices only have config words as FLASH memory. Some devices don't have EEPROM.
; For these devices, we can save code by jumping directly to sending back an
; acknowledgement packet if the PC application erroneously requests them.
WriteConfig:
#else
WriteConfig:
#endif
#endif ; end #ifdef CONFIG_AS_FLASH
#ifndef EEADR
ReadEeprom:
WriteEeprom:
#endif
SendAcknowledge:
clrf EECON1 ; inhibit write cycles to FLASH memory
movf COMMAND, w
rcall SendEscapeByte ; Send only the command byte (acknowledge packet)
rcall AddCrc
SendChecksum:
movf CRCL, W
movf CRCH, W
SendETX:
movlw ETX ; Send stop condition
rcall SendHostByte
bra WaitForHostCommand
; Write a byte to the serial port while escaping control characters with a DLE
; first.
SendEscapeByte:
movwf TXDATA ; Save the data
xorlw STX ; Check for a STX
bz WrDLE ; No, continue WrNext
movf TXDATA, W
movf TXDATA, W
bnz WrNext ; No, continue WrNext
WrDLE:
movlw DLE ; Yes, send DLE first
rcall SendHostByte
WrNext:
movf TXDATA, W ; Then send STX
SendHostByte:
clrwdt
btfss UxPIR, UxTXIF ; Write only if TXREG is ready
bra $-2
movwf UxTXREG ; Start sending
return
ReadHostByte:
btfsc UxRCSTA, OERR ; Reset on overun
reset
WaitForHostByte:
clrwdt
btfss UxPIR, UxRCIF ; Wait for data from RS232
bra WaitForHostByte
movf UxRCREG, W ; Save the data
movwf RXDATA
return
reset ; firmware, these instructions may protect
clrf EECON1 ; against accidental erase/write operations.
; Unlock and start the write or erase sequence.
TableWriteWREG:
movwf TABLAT
tblwt *
StartWrite:
clrwdt
movlw 0x55 ; Unlock
movwf EECON2
movlw 0xAA
movwf EECON2
bsf EECON1, WR ; Start the write
nop
return
END
Release build of project `D:\product data\AN1310 bootloader microchip\PIC18 Bootloader\PIC18 Bootloader.mcp' started.
Language tool versions: MPASMWIN.exe v5.51, mplink.exe v4.49, mplib.exe v4.49
Sat Jan 04 13:01:52 2014
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p18F2620 "PIC18 Bootloader.asm" /l"PIC18 Bootloader.lst" /e"PIC18 Bootloader.err" /y
Executing: "C:\Program Files\Microchip\MPASM Suite\mplink.exe" /p18F2620 -g "PIC18 Bootloader.o" /u_EXTENDEDMODE /z__MPLAB_BUILD=1 /m"PIC18 Bootloader.map" /o"PIC18 Bootloader.cof" /x
MPLINK 4.49, Linker
Device Database Version 1.14
Copyright (c) 1998-2011 Microchip Technology Inc.
Error - section '.org_0' can not fit the absolute section. Section '.org_0' start=0x00000000, length=0x00000000
Errors : 1
Link step failed.
Release build of project `D:\product data\AN1310 bootloader microchip\PIC18 Bootloader\PIC18 Bootloader.mcp' failed.
Sat Jan 04 13:01:53 2014
BUILD FAILED
