Ata-Va
Junior Member level 3
Hello everyone
I Had designed Analog Circuit and now in order to test it,I wanna save data in excel format during simulation and import it into Matlab,I don't know whether in this Circumstance "MatlabSinkF" block of Ads will be useful or not, I Also tested "TimedataWrite" block but it was of no use, even "Write_Var()" command was not useful ,on the other hand because of dealing with big data I don't wanna export it after simulation using result window,now I wanna know if there is a way to do it?
I would be very thankful for any sort of help
thanks alot
thanks alot
