+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 2
    Points: 365, Level: 4
    Join Date
    Nov 2013
    Posts
    Points
    365
    Level
    Thermocouple output voltage isolation in temparature transmitter (4-20mA)
    Hi...
    I need to provide isolation for thermocouple for temparature transmission (4-20mA). Means i have to provide separate ground for thermocouple.. I selected analog devices ADum1100 digital isolator.
    The only source is +24V which i am giving for XTR116 which outputs 4-20mA.
    Problem is Isolation means i need to separate ground of thermocouple (-ve) from remaining grounds. If i use a digital isolator for isolation where +5V required for its operation is supplied by XTR116, isolation between thermocouple ground and other grounds wont happen? Please suggest me some ideas ....
    If still information is required ask me i will post....
    Thanks in advance...
    •   Alt10th December 2013, 13:24
      advertising
  2. #2
    Advanced Member level 5
    Points: 19,978, Level: 34
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,851
    Points
    19,978
    Level
    34
    Re: Thermocouple output voltage isolation in temparature transmitter (4-20mA)
    The thermocouple is an analog device (not to be confused with Analog Devices), a DIGITAL isolator will do you absolutely no good. Also, you don't need to ground the thermocouple, you need to actually use a differential input device. There are LOTS of solutions, here's one: AD8494.
    •   Alt10th December 2013, 15:01
      advertising
  3. #3
    Newbie level 2
    Join Date
    Nov 2013
    Posts
    Points
    365
    Level
    Quote Originally Posted by barry View Post
    Dear sir if i am using digital isolator i can interface this between my pic microcontroller (ADC) and DAC..
    Direct thermocouple interface ICs are available but which are costly.....
    Do AD8494 provides ground isolation? I studied its datasheet, they provide input filtering and amplification.. but not ground isolation...
    or
    Do common-mode rejection feature of ad8494 is same as ground isolation? i think not...
    •   Alt11th December 2013, 06:51
      advertising
  4. #4
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,851
    Points
    19,978
    Level
    34
    I don't understand. What are you isolating from what? Is the thermocouple grounded? What do you mean by "if i am using digital isolator i can interface this between my pic microcontroller (ADC) and DAC"? Your OP said nothing about a PIC. Where is the PIC in your signal chain? Do you want to isolate your PIC from ground?
    Please clarify. A schematic or block diagram would help a lot.
