+ Post New Thread
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 20 of 71
  1. #1
    Advanced Member level 1
    Points: 5,152, Level: 17
    Join Date
    Jul 2004
    India
    Posts
    417
    Points
    5,152
    Level
    17
    Requirements for GSM jammer design
    Well as a small project one of my frnds wanted to design a GSM jammer circuit.
    What wud be the requirements for such a design. He wanted to know more abt this ckt..
    is it possible to jam CDMA signals.. as per my knoledge GSM operates at low power so it wud difficult to jam those signals.. as they do not fall between the high power bands.
    can someone help me reg. this GSM jammin ckt and the basic requirements..
    with regards,
  2. #2
    Points: 11,937, Level: 26
    Join Date
    Jul 2001
    Posts
    1,059
    Points
    11,937
    Level
    26
    gsm jammer schematic
    I do not remember from where I got this but maybe it is a start ...
    Please note that in most countries jammers are illegal!!!!
    best regards
    1 members found this post helpful.
  3. #3
    Full Member level 4
    Points: 3,762, Level: 14
    Join Date
    Nov 2004
    Posts
    220
    Points
    3,762
    Level
    14
    gsm jammer project
    Did anyone test this circuit? Please help me...i'm planning to do this....
    2 members found this post helpful.
    •   Alt14th February 2005, 16:32
      advertising
  4. #4
    Super Moderator
    Points: 15,502, Level: 30
    E-design's Avatar
    Join Date
    Jun 2002
    Posts
    1,953
    Points
    15,502
    Level
    30
    gsm jammer schematics
    It works. PM me if you want more details.
    7 members found this post helpful.
  5. #5
    Full Member level 3
    Points: 5,938, Level: 18
    Tornado's Avatar
    Join Date
    Apr 2002
    Posts
    167
    Points
    5,938
    Level
    18
    gsm jammer schema
    Someone has made some PCB layout?
    Tornado
    3 members found this post helpful.
  6. #6
    Points: 4,476, Level: 15
    Join Date
    Feb 2002
    brazil
    Posts
    422
    Points
    4,476
    Level
    15
    build gsm jammer
    What is "jammer"?
    gorkin
  7. #7
    Points: 5,140, Level: 16
    Join Date
    Jun 2004
    india
    Posts
    487
    Points
    5,140
    Level
    16
    how to make gsm jammer
    jammer is a device which block calls in cell phones. it genarate high frequecy noise signal which should be destore / disconnect the calls in cellphone. we can hear any sound when hammer is place near u.
    sound like FM signal hear in ratio.
    bye
    •   Alt15th February 2005, 02:51
      advertising
  8. #8
    Newbie level 5
    Points: 1,480, Level: 8
    Join Date
    Dec 2004
    Posts
    8
    Points
    1,480
    Level
    8
    cdma jamming
    is it really possible to "jam" a digital signal from GSM phones?
  9. #9
    Full Member level 2
    Points: 4,681, Level: 16
    Join Date
    Mar 2002
    Posts
    147
    Points
    4,681
    Level
    16
    gsm jammer
    Yes
    This is possible for limited area.
  10. #10
    Member level 5
    Points: 3,700, Level: 14
    jhallows's Avatar
    Join Date
    Jan 2000
    Posts
    83
    Points
    3,700
    Level
    14
    make gsm jammer
    What are the following parts on the schematic:
    M2 28 x 400
    L6 No part number given
    947T IC? Module?
    •   Alt16th February 2005, 19:17
      advertising
  11. #11
    Join Date
    Jul 2004
    India
    Posts
    417
    Points
    5,152
    Level
    17
    gsm jammer scheme
    well dude it is possible to jam only GSM Signals and not CDMA.. coz CDMA can never be jammed thats the nature of such phones..low power..
    with regards,
  12. #12
    Member level 3
    Points: 2,113, Level: 10
    Join Date
    Aug 2003
    Posts
    67
    Points
    2,113
    Level
    10
    gbppr.org
    " it is possible to jam only GSM Signals and not CDMA.. coz CDMA can never be jammed ... "
    Unforunatelly not true. Any communication system can be jammed. To do it with CDMA you need approx 20 dB more power as for GSM for the same distance, but if you want to do it in your room... (but it is illegal, too)
  13. #13
    Newbie level 5
    Points: 1,442, Level: 8
    Join Date
    Feb 2005
    Posts
    8
    Points
    1,442
    Level
    8
    simple gsm jammer circuit
    can any one give me detail ckt about the components and the related data on JAMMER. i m doing a project on this . please help me
    byom
  14. #14
    Member level 5
    Points: 2,640, Level: 11
    Join Date
    Feb 2005
    Posts
    87
    Points
    2,640
    Level
    11
    how to make a gsm jammer
    is there any easy GSM Jammer to built to cover 10*10 Meter Area ?
    and i need more details about the jameer here in this topic , details about the components whitch you used to make your Jammer circuit
    Regards
  15. #15
    Member level 1
    Points: 1,710, Level: 9
    Join Date
    Sep 2004
    Posts
    35
    Points
    1,710
    Level
    9
    circuit gsm jammer
    Where can I get the details of the circuit? can you post it here?
    thanks in advance
  16. #16
    Full Member level 3
    Points: 3,798, Level: 14
    Moss's Avatar
    Join Date
    Jul 2001
    Posts
    170
    Points
    3,798
    Level
    14
    gsm jammer pdf
    In case that you use narowband signal for jaming, indeed you need 20dB more power. If you use jaming signal with bandwith comparable with CDMA signal you didn't need more power. That is theory...
    In real world, you allways will have 20 dB( and many more) in close field over CDMA signal, because he is very weak.
    •   Alt2nd March 2005, 10:42
      advertising
  17. #17
    Member level 5
    Points: 2,078, Level: 10
    actra's Avatar
    Join Date
    Nov 2004
    cairo [EGYPT]
    Posts
    90
    Points
    2,078
    Level
    10
    gsm jammer pcb
    i think every system need different technique for jamming
    GSM needs a sweep carrier that sweeep all the workin GSM band fast...
    CDMA need a CW or narrowband noise!!
    Added after 4 minutes:
    check this website ...it has a detailed project with pictures abotu how to construct a GSM jammer for the 900mhz band :
    http://kleiner-onkel.de.vu/
  18. #18
    Member level 5
    Points: 1,816, Level: 9
    prinsloo's Avatar
    Join Date
    Sep 2004
    Bethlehem RSA
    Posts
    93
    Points
    1,816
    Level
    9
    gsm jammer circuits
    Try this jammer www.gbppr.org
  19. #19
    Full Member level 6
    Points: 4,707, Level: 16
    Buriedcode's Avatar
    Join Date
    May 2004
    London
    Posts
    357
    Points
    4,707
    Level
    16
    schema jammer
    hi, just thought I'd butt in here,
    I'll for-go the 'moral' issues raised by this, and the warnings of legality, since it would be breaking the law. Most countries come down very heavy on such actions, not just 'radio' emissions, but specifically phone interference. Safe to say, I strongly disagree, on many levels.
    You're all talking about GSM, off the top of my head, second generation mobiles (most common) work on 900 and 1800Mhz. Uplink and downlink are separated by about 50Mhz, band width is 25Mhz for 900, and 50Mhz for 1800. CDMA phones are very tolerant to interferers, but they can be jammed, just like you 802.11b LAN can be jammed, although the spreading sequence in CDMA and code are significantly longer. All these systems have hopping capability, and will hop anyway from time to time to spread network traffic (no-one has the same channel for long). If you are near a base station that has both 900 and 1800Mhz capability, and you want to jamm all mobiles in a specific area, you would need two separate transmitters. OR - A big, fat, dirty transmitter that spits out harmonics like their going out of fashion :)
    Although all mobile GSM systems are really good at coping with this, you wouldn't have to damage the radio links too much for mobiles to stop working. Most phone companies would rather cut you off than give you a 'bad line'. peoples phones would still show they have coverage, but they would be unable to make or recieve a call.
    My advice would be, keep it simple. You want a wideband transitter to nail either the uplink, or downlink. (I would go with downlink since the signal from the phone is strong, and the signal from the BS is weak, and you would be nearer to the phones). Also, let there be harmonics, specifically, 2nd order (double the centre frequency), that way you can get 900Mhz and 1800 at the same time. So just build a FM transmitter, feed it with noise to randomise and spread the band, and don't bother with the usual hassle of reducing emissions. Sharp edges in your PCB, no shielding, and lots of power (3-5watts?). No point in complicating it, unless you want to 'eaves-drop' in which case, it becomes an electronics nightmare.
    Still disapproving,
    BuriedCode
  20. #20
    Full Member level 5
    Points: 2,921, Level: 12
    Join Date
    Jan 2005
    Posts
    255
    Points
    2,921
    Level
    12
    simple jammer
    Quote Originally Posted by prinsloo
    this link not work
