+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Newbie level 6
    Points: 101, Level: 1
    Join Date
    Nov 2013
    Posts
    11
    Points
    101
    Level
    control system, poles and stability response
    Can you help me compare these results? They're the simulations of a closed loop system . When we change the poles, (in this case, there are 4 poles), the response system also changes. The 4 poles involves 2 complex numbers and 2 integers, but I don't see the relationship between the poles and the response. I don't see an exact description. I mean, a description like:
    if the real number is increased, then the response would be more oscillatory or if the imaginary part is smaller, then the faster the convergence to 0.
    Help, please?
    Click image for larger version.
ID:	98979Click image for larger version.
ID:	98980Click image for larger version.
    •   Alt25th November 2013, 02:38
      advertising
  2. #2
    Advanced Member level 5
    Points: 19,088, Level: 33
    Achievements:
    Created Blog entry Created Album pictures 7 years registered
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Re: control system, poles and stability response
    Help, please?
    Hi MissP.25_5
    I don't see anything surprising ! when you change location of poles of a circuit response of a circuit will be involved by some changes which depends on where are the poles exactly .
    A suitable Article from MIT can lead you through a good understanding :
    http://www.google.com/url?sa=t&rct=j...56988011,d.cGU
    Best Wishes
    Goldsmith
    When you sensed that i can help you , feel free to ask me .
    Experience is a good professor of mine !
    The only thing that i couldn't understand yet , is why humans should fight together ? why not helping each other to have a better world ?
    •   Alt25th November 2013, 04:03
      advertising
  3. #3
    Newbie level 6
    Join Date
    Nov 2013
    Posts
    11
    Points
    101
    Level
    Quote Originally Posted by goldsmith View Post
    Hi MissP.25_5
    Best Wishes
    Goldsmith
    Yes, that's what I said. The response depends on the poles. But I need to compare these 3 results. They're the results of 3 different poles. I also need to write the relationship between the complex numbers and the response. Can you help?
    •   Alt25th November 2013, 04:25
      advertising
  4. #4
    Points: 39,702, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,689
    Points
    39,702
    Level
    48
    MissP - it is not easy to answer your question because it is not clear which parameters of the closed-loop sysytem are shown.
    Watching the first line I see something like a step response, correct?
    In this context, I am confused about the last line showing an input. Which input?
    As a general (and preliminary) answer:
    A complex pole pair causes overshoot in the step response. When the (negative) real part of these poles come closer to the origin (imag. parts constant) the overshoot increases.
    Moreover, a negative real pole (at s=-sigma) causes a damping of the step response corresponding to exp(-sigma*t). Thus, the duration of the step response is inverse proportional to sigma.
    I think, the time response (first line) can confirm these statements.
    1 members found this post helpful.
  5. #5
    Newbie level 6
    Join Date
    Nov 2013
    Posts
    11
    Points
    101
    Level
    Quote Originally Posted by LvW View Post
    The input is the voltage input used to produce the torque for the pendulum arm to oscillate. The poles consist of 2 pair of real numbers and 2 pairs of conjugate numbers. What do the real numbers say about the response?
    •   Alt25th November 2013, 10:18
      advertising
  6. #6
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,689
    Points
    39,702
    Level
    48
    Quote Originally Posted by MissP.25_5 View Post
    Sorry to say but your answers do not clarify things.
    However, at least I have learned that the system input is NOT a voltage step - correct?
    In this case, it is rather complicated to verify/justify/explain the system response.
