+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 2
    Points: 1,636, Level: 9
    Achievements:
    7 years registered
    thudpucker's Avatar
    Join Date
    Feb 2007
    North Alabama
    Posts
    50
    Points
    1,636
    Level
    9
    Wireless Tachometer schemetic and questions on the Pickup?
    I see a Wireless Tachometer. Also an Infra-red Tachometer.
    Both on Ebay.
    What 'pickup' do they have? I thought I'd make one, if it's not too complex.
    Thanks for any advice (other than buying one) that I may use.
    •   Alt20th November 2013, 08:35
      advertising
  2. #2
    Junior Member level 3
    Points: 467, Level: 4
    bsprajc's Avatar
    Join Date
    Apr 2012
    Santa Clara, CA, USA
    Posts
    28
    Points
    467
    Level
    Re: Wireless Tachometer schemetic and questions on the Pickup?
    Maybe they use an inductive pickup on the coil wire, feed into a clamping diode and a rectifying diode, fed into an opto-isolator... ?
    •   Alt20th November 2013, 18:10
      advertising
  3. #3
    Advanced Member level 5
    Points: 16,136, Level: 30
    Join Date
    May 2010
    Santa Barbara
    Posts
    2,832
    Points
    16,136
    Level
    30
    Without details it is impossible to answer your question. Some tachometers use an induction coil and a magnet on the wheel, others use IR sensors to trigger tachometer circuit.
    The common in most tachometers is that their sensors generate pulses, some once per wheel revolution, others many pulses per revolution. You can buy the cheapest and try your sensor with it. I would start on my friend's tacho, disconnect the sensor and try how it operates, Then buy a similar type.
