[PIC] Pic18F4550 & SIM300 (Monitor & control device using SMS). problem in reading "OK"
KVN1477
Junior Member level 3
I have developed code to establish communication between SIM 300 GSM modem & PIC 18F4550 code is as follows...in Micro C pro.
i am sending AT command to Gsm modem & trying to DISPLAY "0K" ON lcd....
BUT PROGRAM STOPS DISPLAYING "Testing com..."
i am unable to understand weather "AT" is getting send to GSM modem and weather Modem is replaying with "OK"......
pls, help me to read & display "OK" from GSM modem..
// LCD module connections
sbit LCD_RS at LATB4_bit;
sbit LCD_EN at LATB5_bit;
sbit LCD_D4 at LATD4_bit;
sbit LCD_D5 at LATD5_bit;
sbit LCD_D6 at LATD6_bit;
sbit LCD_D7 at LATD7_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISD4_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D7_Direction at TRISD7_bit;
// End LCD module connections
char gsm_response[20];
void gsm_send_command(char *command)
while(*command)
uart1_write(*command++);
uart1_write(10);
uart1_write(13);
//Delay_ms(700);
void main()
PORTB = 0x00;
LATB = 0x00;
ADCON1 = 0x0F; // Configure AN pins as digital
CMCON=0; // comparator off
UART1_Init(9600); // Initialize UART module at 9600 bps
Delay_ms(200); // Wait for UART module to stabilize
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,1,"Smart Home..."); // Write text in first row
Delay_ms(2000);
lcd_out(1,1,"Testing com...");
gsm_send_command("AT");//send AT to modem using subroutin
do
UART1_Read_Text(gsm_response,"OK ",2);// read response from Modem until OK received and save in variable gsm_response
}while (UART1_Data_Ready()==1);
Lcd_cmd(_Lcd_clear);
Lcd_out(1,1,gsm_response);// Display OK
delay_ms(5000);
Re: Pic18F4550 & SIM300 (Monitor & control device using SMS). problem in reading "OK"
Try this code. If this doesn't work then connect your modem to PC and send AT from Terminal software. It should give response like >OK. Just post the screenshot of the response you get.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
unsigned char gsm_response[5], i = 0;
void main()
    PORTB = 0x00;
    LATB = 0x00;
    Delay_ms(2000);
    LCD_Out(1,1,"Testing com...");
    while(1)
        UART_Write_Text("AT\r\n");
        while(gsm_response != ">OK"){
            gsm_response[i++] = UART1_Read();
            gsm_response[i] = '\0';
        Lcd_cmd(_LCD_CLEAR);
        Lcd_out(1, 1, gsm_response);
        Delay_ms(5000);
Is SIM300 working ok on hyper terminal in all condition such SMS sending Receiving. If yes then test controller code on Hyper terminal & check it show require data on hyper terminal if both above condition work then only send data from controller to sim300
thanks.....
compiler is sending error for ur code for "while(gsm_response!="OK")" as - - Operator '' is not applicable to these operands
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
void main()
    PORTB = 0x00;
    LATB = 0x00;
    Delay_ms(2000);
    while(1)
        Delay_ms(5000);
Thanks GE.....
Modem is working properly with Hyper terminal
As per ur guidance i must check Circuit by connecting it to PC
i will let u know o/p afterward...
Replace
Code C - [expand]
by
Code C - [expand]
while((gsm_response[0] != '>') && (gsm_response[1] != 'O') && (gsm_response[2] != 'K')){
