Behaviour of water with ions in electrical field within frequency range 0.1 - 10 MHz
luben111
Advanced Member level 1
UK
Does somebody know how the water with ions inside (for example tap water) behaves in electric field in the frequency range 100 KHz - 10 MHz? The ions in the water are increasing the conductivity of the water, the question is - are there some non linear effects like:
- the conductivity of the water in this frequency range depends on the amplitude of the applied electrical field
- the conductivity of the water depends on the frequency in this particular frequency range
Thank you.
Kind regards,
Luben
About conductivity vs. frequency, some data is available on the ITU reccomendation:
It seems to be constant in your frequency range.
Thank you albbg,
I think it's exactly what I needed to confirm my experimental data. As I see the conductivity in 0.1 - 10 MHz range is constant.
Kind regards,
Luben
