[SOLVED] 5*7 led matrix iddentification problem common anode or cathode
vijay satija
Junior Member level 1
panipat
How to know about the common anode and common cathode of led matrix and it has 14 pin 7 upper and 7 lower what about pin description ?
ok this is a simple differance
Why don't you simply test its polarity and pins with the DIODE TEST function on a multimeter?
When the polarity is correct then the segment will light dimly.
If you do not have a multimeter then the polarity and pins can be checked with a 9V battery in series with a 1k resistor.
from your image its common Anone 7 segment display
A - Anode , K - Cathode ( see image)
i know what is common anode and cathode but i cant identify in led matrix by keyword written on it
try to post some image if u have 5x7 led matrix .
Maybe it is an LED IC with 35 LEDs instead of having 7 segments:
EDIT: It took such a long time to attach this image that I thought attachments do not work anymore.
its not common anode or catchode
kR - is Cathode (K) Row
aC is Anode (A) Column
Eg
kR1 is Cathode of Row 1
aC1 is Anode for Column 1
To power on 1st led connect kR1 and aC1
