jedreg
Newbie level 3
I am designing and building device that will work outdoor self-powered using solar panel and battery. Solar panel rated 10W gives Im=0.65A (short-circuit) and has power peak at Um=16.8V (21V open-circuit). The VRLA battery from Yuasa is rated 4Ah 12V (13.65V floating). I followed data sheet and designed circuitry with C/10 loading (no timer) so for this battery it is 0.45A limited by Rsense=0R22 and using extra 6v2 zener diode for BOOST pin proper voltage range. I am using tantalum capacitors as Cout/Cin (4u7/20V as I could not find 10u) as well as boost capacitor (2u2 between SW and BOOST). Power inductor initially used are rated 2.5A; I tried 15uH (approximated from other designs) and 68uH (calculated from datasheet).
Using lab power supply I observed that charging starts correctly when voltage reaches Um voltage. Problem starts when LT3652 is charging. I measured ~0.2A as charging current with voltage drop close to 45mV on Rsense (so it is not problem with current limiter that applies at 100mV). I was trying different power inductors from 4u7 to 220uH giving different max charge current, all far from expected maximum. I tried different capacitors, electrolytic produced even lower current. When charging IC gets really hot and it should not be that much for such low current (2A rated chip).
As I am not sure about tantalum caps rating, is it possible for such problems with their regular ESR (not low-ESR)?
Would PCB layout lead to overheating and current drop? (I expect that design flaws would lead to noise emission, grounding problems with non-zero referential voltage etc).
regards,
-andy.
regards,
-andy.
