+ Post New Thread
Results 1 to 6 of 6
4th October 2013, 17:42 #1
- Join Date
- May 2011
- Location
- Grenoble
- Posts
- 94
- Helped
- 10 / 10
- Points
- 1,599
- Level
- 9
Current Mirror OTA gain calculation
Dear all,
I designed a current mirror. Some papers such as http://www.imec.be/esscirc/essderc-e...ons/063_50.pdf said the DC gain is
A0 = gm1 x B x ro3.
I computed it with mine, but, in the simulation, the B factor doesn't seems to have any impact on the DC gain, only on the GBW. Not sure if there is a reason, my inputs transistors are working in subthreshold region.
Any Idea, suggestions?
Thank you...
5th October 2013, 16:26 #2
8th October 2013, 16:24 #3
- Join Date
- May 2011
- Location
- Grenoble
- Posts
- 94
- Helped
- 10 / 10
- Points
- 1,599
- Level
- 9
Re: Current Mirror OTA gain calculation
OK, thank you for you answer. So the B factor doesn't have any impact as the ro will change with B...
But, if the gain is boosted B times and the output resistor is reduced B times, it means the DC gain is gm1 x ro3, doen't it?
If yes, the gm1 is 12.8µS (qID/nkT) and ro3 = 5.5MOhms... it gives only 70 so 37dB...
8th October 2013, 17:04 #4
8th October 2013, 21:50 #5
- Join Date
- May 2011
- Location
- Grenoble
- Posts
- 94
- Helped
- 10 / 10
- Points
- 1,599
- Level
- 9
OK, so I probably made a mistake when I calculate ro3...
For gm1, in subthreshold I've only this equation: gm1 = qId/nkT (from Martin's book)
9th October 2013, 16:06 #6
+ Post New Thread
Please login
