+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Newbie level 2
    Points: 18, Level: 1
    Join Date
    Sep 2013
    Posts
    Points
    18
    Level
    SISO design using behaviourial modeling in verilog
    I have written verilog code for 4 bit Serial in serial out.
    module siso(
    input clk,reset,in,
    output reg [3:0] out);
    reg [3:0]temp;
    always @ (posedge clk)
    begin
    if (reset)
    begin
    out <= 0;
    temp <= 0;
    end
    else
    begin
    temp[0] <= in;
    temp <= temp << 1;
    out <= temp[3];
    end
    end
    endmodule
    output is coming 0000 and even in temp input is not loading. I am not understanding why its happening like this.
    if i swap the statements
    temp[0] <= in;
    temp <= temp << 1;
    as
    temp <= temp << 1;
    temp[0] <= in;
    output is coming.
    PLZ tell me why its not working with the previous structure.
    Thanks in advance
    •   Alt19th September 2013, 07:05
      advertising
  2. #2
    Super Moderator
    Points: 28,611, Level: 41
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,550
    Points
    28,611
    Level
    41
    Re: SISO design using behaviourial modeling in verilog
    temp <= temp << 1;
    Shifts a 0 into the LSB.
    You should code a shift register like this...
    temp <= {temp[2:0], in};
    Which does the exact same thing as this...
    temp[0] <= in;
    temp[1] <= temp[0];
    temp[2] <= temp[1];
    temp[3] <= temp[2];
    Which will work regardless of the ordering of the assignments.
    Regards
    •   Alt19th September 2013, 07:34
      advertising
  3. #3
    Newbie level 2
    Join Date
    Sep 2013
    Posts
    Points
    18
    Level
    Quote Originally Posted by ads-ee View Post
    temp <= temp << 1;
    temp[0] <= in;
    temp[1] <= temp[0];
    temp[2] <= temp[1];
    temp[3] <= temp[2];
    Regards
    thanks for the reply but i have checked with the same after swapping both the statement it is not giving the output.
    •   Alt19th September 2013, 08:37
      advertising
  4. #4
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,550
    Points
    28,611
    Level
    41
    Quote Originally Posted by dkvlsi View Post
    What statements are referring to? Post the code.
  5. #5
    Newbie level 2
    Points: 735, Level: 5
    Join Date
    Nov 2009
    Posts
    Points
    735
    Level
    ads-ee is correct....
    just check this code.....
    begin
    if (reset)
    begin
    out <= 0;
    temp <= 0;
    in <= 1'b1; //just for testing make it "1"...
    end
    else
    begin
    //$display(" value of in %d",in);
    //temp[0] <= in;
    //$display(" value of temp[0] %d",temp[0]);
    //temp <= (temp << 1);
    $display("value of temp %b",temp);
    out <= temp[0];
    end
    end
    it's working very fine.....
    •   Alt20th September 2013, 05:15
      advertising
  6. #6
    Newbie level 1
    Points: 13, Level: 1
    Join Date
    Oct 2013
    Posts
    Points
    13
    Level
    I think to reflect SISO operation...
    module siso(
    input clk,reset,in,
    output reg out );
    reg [3:0]temp;
    begin
    if (reset)
    begin
    out <= 0;
    temp <= 0;
    //in <= 1'b1; //just for testing make it "1"...
    end
    else
    begin
    //$display("value of temp %b",temp);
    out <= temp[3];
    end
    end
    endmodule
