could anyone advise how to implement the process circuit?
Are you using any processor here or else any microcontrollers?
if you ain't using microcontroller go through with multivibrator or 555 timer ICs.
I've attached some documents here, check it out and update me.
Best regards,
Can be hardly solved without a complex digital circuit, involving a clock generator, a pulse width measuring counter, a programmable timer to reproduce the period, a sequence controller.
