How to write a C code in 64-bit fixed point?
boeysue
Full Member level 3
How to write a 64-bit fixed point C code in unix ?Because in unix ,the operation of 64-bit fixed point is not right...So can anyone tell me how to write a 64-bit fixed point operation in C code!thanks for help!
64-bit integer syntax tends to be non-portable on 32-bit compilers. Which compiler are you using, and what problem are you seeing? Post a small program that demonstrates the problem.
This works in MinGW GCC 3.4.2, but the long long, LL, and %I64d may be different on your compiler:
#include <stdio.h>
int main(void)
  long long a=1122334455667788LL, b=1000;
  printf("product=%I64d\n", a*b);
  return 0;
product=1122334455667788000
64-bit long long
the operation with shift and + seems to be wrong.
Because I use the server to change the 32-bit directly to 64-bit,It seems to be saturated on 2^16.
So I just think the ansi didn't support the operation of 64-bit operation.
By the way,What is the answer to help me of the shift/add operation on 64-bit!
Thanks a lot.
Tell us your compiler version and show us your non-working code so we can help you.
What do you mean, use server to change 32-bit to 64-bit??
ANSI doesn't specify the number of bits. That's compiler dependent.
Actually I just do a cic decimation filter just as my decimation is 128 and my stage is 5th order,then I see the output of the bitstream stick to 2^16.
By the way,How to use the cicdecim command on matlab?The IWL/OWL setting seems strange ,maybe I get the wrong idea about it.
plz help me..
I've never used that MATLAB filter. Type this command to see lots of info and examples:
doc mfilt.cicdecim
Actually I use +1/-1 as input ,and setting IWL = 1,there is many warning message.
But if I use IWL = 2,the output bitstream seams error..
So I make confused of the introduction of mathworks.
union {
unsigned long x;
unsigned long y;
this is a 64-bit integer is it right?
union {
unsigned long x;
unsigned long y;
no unsigned long x and y resides in the same place . size of struct is equal to
sizeof longest data type .
sizeof(union { unsigned long x; unsigned long y; }) = sizeof( unsigned long );
you can define like this
typedef struct
unsigned long upperPart;
unsigned long lowerPart;
} int_64_Bits;
but you cannot use this structure directly in arihtmetic operations. you mast define custom operators or functions
mmm..
Do you mean it need to take apart to two 32-bit part?
But how to do the operation of add and multiply?
Especially multiply....
Thanks for answering.
How to use two part in unix without assembly?
Because the carry-out bit after the operation of addition,It is the problem I couldn't understand.
Plz help.
Look at the:
There is definition of <inttypes.h> header file.
Can you express more clearly?
Which parameter or variables did it use for that?
Because I print the __WORDSIZE ,it is 32.I dont use it for extending for 64-bit operation.Thanks for that.
Added after 7 minutes:
this seems problem...
long long x=0x01<<33;
printf("%x\n",x);
But I don't know why the following is correct:
long long x=0x01;
printf("%x\n",x<<33);
Thanks for help lorh..
It seems to bother me so long long time.
By the way,the compiler I used is gcc 2.96.
Added after 12 minutes:
mmm..
the machine is i686.//uname -m
compiler is gcc-2.96.//man gcc
and how to get more information in command?
thanks for help ...
Boeysue, at last you are giving us some information! But it's still not enough.
If you compile that with the -Wall option (full warnings), gcc should warn you that your printf has inconsistent int format and argument type. Your %x tells printf to assume an int argument (apparently 32-bits in your compiler). Try %llx or %I64x instead. I can't guess the exact syntax, because it depends on your operating system and precise compiler version (type gcc --version).
... addition ...
Ok, i686 means it's a Pentium box. 32-bit integers as you determined. I haven't used that exact compiler, but %llx is a good candidate. Try it!
I don't understand "how to get more information in command?". Maybe you are asking about -Wall. I run the compiler like this:
gcc -Wall myprogram.c
printf("%x\n",x);
long long x=0x01;
Actually,In long long x=0x01<<33;//<---- this happens to be wrong...
the warning message is left shift is more than width of the type.
But when i print sizeof long long it is 8. So I am confused of this.
No, 0x01 is a 32-bit int on your compiler, so shifting it by 33 bits gives you trouble. You will have better luck with this:
long long x=0x01LL<<33;
What did this output on your compiler?
long long x=0x01;
I would expect "0" or maybe "2" but not the desired result "200000000"
I'm guessing that this will produce the expected result "200000000":
long long x=0x01;
printf("%llx\n",x<<33);
    boeysue
mmm...
That's right...It helps me not to doing many nonuseless thing for work.Because I see many document not to recommand to write more than 32 bit code.So the above discussion helps me much more ,thanks.
Does there exit any detailed document about gcc's tools?thanks for help :sm9:
