+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Member level 1
    Points: 158, Level: 2
    Join Date
    Aug 2013
    Posts
    33
    Points
    158
    Level
    Installing ORCAD
    how am i to install ORCAD to my PC?i have the software but when i install it they are asking for key codes, if so am i supposed to type all the key codes given or only one key code, because when i typed only one key code and after installation when i tried to open the program, it says the feature you added is not suitable to this PC. Please help me and make me clear on this.
    •   Alt5th August 2013, 09:56
      advertising
  2. #2
    Advanced Member level 1
    Points: 2,811, Level: 12
    Join Date
    Sep 2012
    Pakistan
    Posts
    414
    Points
    2,811
    Level
    12
    Re: Installing Orcad - product key codes?
    the files with the key code usually has all this information
    If you Believe everything you Read, Better Don't Read!
    •   Alt5th August 2013, 10:43
      advertising
  3. #3
    Member level 1
    Join Date
    Aug 2013
    Posts
    33
    Points
    158
    Level
    That's true. what i'm asking is am i supposed to type all the keycodes when installing
    •   Alt5th August 2013, 10:58
      advertising
  4. #4
    Join Date
    Sep 2012
    Pakistan
    Posts
    414
    Points
    2,811
    Level
    12
    yes i guess that will then enable all option..
    try it
  5. #5
    Member level 1
    Join Date
    Aug 2013
    Posts
    33
    Points
    158
    Level
    Ok let me try and see.thankyou
    •   Alt5th August 2013, 12:15
      advertising
  6. #6
    Administrator
    Points: 69,113, Level: 64
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,113
    Level
    64
    Blog Entries
    During the ORCAD installation process, you normally are asked for the location of the license file which contains all your current licensing information.
    Typically you only need to manually enter license keys if you are adding features after the initial installation and only then if a new license file is unavailable.
    BigDog
    The Edge... there is no honest way to explain it, because the only people who really know where it is are the ones who have gone over.
    -- Hunter S. Thompson
