+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Points: 30, Level: 1
    Join Date
    Jun 2013
    Posts
    Points
    30
    Level
    interfacing 8086 with usb
    Hi everyone!
    Is there any way to interface 8086 with usb? I need its simulation in proteus.
    And how can i do that with 8051 instead of 8086?
    Is the circuit in link below true?
    http://chetanpatil.info/1/post/2012/...-lcd-8051.html
    Thanks all
    •   Alt26th June 2013, 18:56
      advertising
  2. #2
    Banned
    Points: 23,048, Level: 36
    Join Date
    Dec 2012
    Bangalore, India
    Posts
    4,294
    Points
    23,048
    Level
    36
    Re: interfacing 8086 with usb
    The circuit is wrong. You need USB to TTL converter.
  3. #3
    Super Moderator
    Points: 239,557, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,557
    Level
    100
    I guess you mean USB-to-serial bridge, e.g. FT232.
    1 members found this post helpful.
  4. #4
    Join Date
    Jun 2013
    Posts
    Points
    30
    Level
    Thanks FvM! Is there any library for FT232 in proteus?
    •   Alt26th June 2013, 22:12
      advertising
  5. #5
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,557
    Level
    100
    Obviously not. Proteus is supporting USB communication simulation for a few USB microcontrollers only.
    •   Alt28th June 2013, 10:14
      advertising
  6. #6
    Join Date
    Jun 2013
    Posts
    Points
    30
    Level
    Thanks for reply. I tried Altium designer too, but it seems doesn't have FT232R simulation model file too.
    What simulator should i use? I have a project with the final circuit like this: http://chetanpatil.info/1/post/2012/...-lcd-8051.html
    I'm really grateful helping me doing this project.
    Quote Originally Posted by FvM View Post
  7. #7
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,557
    Level
    100
    I don't know what you want to achieve with simulation in this case.
    Regarding the said link, jayanth already stated that the circuit can't work as shown.
    It's not even clear what's the intended pupose of USB interface in this case. Apparently the author has only vague ideas about USB, e.g. when he mentions communication with USB sticks, which actually requires an USB hist interface.
  8. #8
    Join Date
    Jun 2013
    Posts
    Points
    30
    Level
    My project is simulation of receiving data from USB and showing it in LCD display.
    like this pic:
    http://obrazki.elektroda.pl/2122020000_1372414658.png
  9. #9
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,557
    Level
    100
    I fear that won't work. Contact your tutor to update the specification.
    It might work with a PIC18 USB controller and Proteus.
  10. #10
    Join Date
    Jun 2013
    Posts
    Points
    30
    Level
    Is there any way to load a code or firmware into 8051 or 8086 to work just like PIC18 USB controller? I mean like v-usb for AVR: http://www.obdev.at/products/vusb/index.html
    •   Alt28th June 2013, 19:08
      advertising
  11. #11
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,557
    Level
    100
    I didn't expect that you are referring to VUSB or a similar solution. It's limited to low speed USB. It surely can't work with standard 8051 that is working at 1 MIPS only. And it rarely can be simulated with Proteus.
