+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 1
    Points: 1,221, Level: 7
    Join Date
    Oct 2007
    Posts
    37
    Points
    1,221
    Level
    7
    Using 8-bit MCU with an PCI graphics card?
    There are some projects that use an 8-bit MCU like the ATmega to control an ISA graphics card like this:
    http://tinyvga.com/avr-isa-vga
    Now could the same be done using a PCI graphics card by completely violating any offical standard?
    The memory and video generation is available on the board. One only needs a way to enter configure and enter some pixel data into it?
    •   Alt22nd June 2013, 05:07
      advertising
  2. #2
    Super Moderator
    Points: 70,434, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,521
    Points
    70,434
    Level
    64
    Re: Using 8-bit MCU with an PCI graphics card?
    PCI and ISA are quite different in operation. ISA is simply treated as a parallel peripheral with the usual read/write control, address and data bus connections but PCI has a protocol of it's own which you have to 'negotiate' before communicating with it. It isn't impossible to do but it would be far more complicated than the ISA version and I think (long time since I worked on PCI systems!) you need to talk via a 32-bit bus so the 8-bit processor would need additional address and data multplexers/ latches.
    Brian.
    PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
    It's better to share your questions and answers on Edaboard so we can all benefit from each others experiences.
    •   Alt22nd June 2013, 09:40
      advertising
  3. #3
    Member level 1
    Join Date
    Oct 2007
    Posts
    37
    Points
    1,221
    Level
    7
    My idea would be to wire the PCI CLK to one of the I/O pins on the MCU such that it can control the speed. The datasheets for graphic cards so far seems to indicate that CLK period has to be longer than 30 ns, no maximum time is defined. Then one writes desired address into the configuration register and supply the same address to write to it's I/O registers.
    If CLK is 33 MHz this task is too hard, but when the datasheet says longer than >30 ns = OK it's a very different circumstance. When you can control CLK a response time of 1/2 clock cycle is no longer a problem. And onboard DRAM seems to be handled using other onboard oscillators.
    A second option i perhaps jtag? provided one can initialize and enter data into graphics bitmap that way.
    •   Alt22nd June 2013, 18:00
      advertising
  4. #4
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,521
    Points
    70,434
    Level
    64
    In principle it can be done and I don't think clock speed is particularly important, at least during the initialization stages. Where I think you may run into problems is the allocation of addresses and IRQs. In an ISA system these are normally decided by hardware links or an addressable configuration register but in a PCI system you have to send requests to the graphics card for it to advise of it's options and then use these to set the final parameters. It's certainly do-able but the software is far more complicated.
    I'm not sure JTAG would work, it is normally used for hardware programming and configuration before the card starts up under it's own control, I've never heard of it being used to actually define or display graphics.
    Brian.
