+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 5
    Points: 2,087, Level: 10
    Join Date
    Nov 2012
    India
    Posts
    266
    Points
    2,087
    Level
    10
    LED indication in triac switching
    I want to glow an led whenever triac switching and powers the load. So i gave a circuit as attached image.
    Click image for larger version.
Name:	Copy of MOC3021.JPG
    The led is glowing properly on first switching. But when the triac is switching next time the intensity of led is diminishing and on next switching it is also flickering. After some 20 switching led died completely. I am switching and kept it ON for about 10 seconds and off it for about 5 seconds. Here the load is induction motor.
    I put the voltage drop across each component in the figure. Why it is happening like this?
    Before to this, instead of RC i just used a resistor of 55K but when triac is ON led glows properly but when triac is OFF also the led is glowing blurry.
    What should i do for the proper led glowing?
    Thanks,
    Murugesh
    •   Alt20th June 2013, 13:10
      advertising
  2. #2
    Full Member level 5
    Join Date
    Nov 2012
    India
    Posts
    266
    Points
    2,087
    Level
    10
    Re: LED indication in triac switching
    Any solution please!!!
    •   Alt21st June 2013, 05:09
      advertising
  3. #3
    Full Member level 5
    Points: 3,271, Level: 13
    Achievements:
    7 years registered
    amitjagtap's Avatar
    Join Date
    Jan 2007
    Posts
    304
    Points
    3,271
    Level
    13
    Basically you want to drive LED with AC source... For this you can use Capacitor voltage divider instead of voltage divider. there will very less dissipation in capacitor voltage divider.
    One important thing is...18V across single LED is too much...Thats why it is flickering and died in 3-4 turns. calculate capacitor voltage divider so that Iled =20mA max and Vled=3V....Normally...(LED current n Voltage also depends on colour of LED)....
    Check out the link below for more details.....
    http://homemadecircuitsandschematics...ed-driver.html
    Note that this design is for High power 1W LED...
    Other link is ..
    http://www.circuit-finder.com/catego...e-powered-leds
    Hope this helped you........
    "Doubt grows with knowledge."
    "The best way to have a good idea is to have a lot of ideas"....Linus Pauling
    •   Alt21st June 2013, 05:40
      advertising
  4. #4
    Super Moderator
    Points: 70,369, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,508
    Points
    70,369
    Level
    64
    There is AC across the LED so it's probably the excessive reverse voltage that damaged it. If you want to show when the AC is being TOLD to turn on, connect the LED and a series resistor across the LED in the opto-coupler, this also isolates it from high voltages. If you want to show when the AC is ACTUALLY on, use your existing schematic but connect the LED across the DC arms of a bridge rectifier and the other components to the AC arms. If you are using a small indicator type of LED, you can make the bridge rectifier from four 1N4148 or similar, it doesn't have to be a high voltage or high current type.
    Brian.
    PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
    It's better to share your questions and answers on Edaboard so we can all benefit from each others experiences.
  5. #5
    Full Member level 5
    Join Date
    Nov 2012
    India
    Posts
    266
    Points
    2,087
    Level
    10
    Well thanks brian..
    I had a thought of putting the LED in the input side of optocoupler, which you meant as "AC is being TOLD to turn on".
    But i want to show when the AC is actually ON - So i put a resistor and capacitor before to LED to have net resistance of 68230 ohm for current limiting ((230 - 1.8 ) / 68230 = 3.3mA which is enough for me) for the 230V/50Hz AC supply.
    The main doubt for me is how i am getting 18V across LED when i measured using DMM across LED terminals. Also i measured the voltage from the TRIAC as 224V(across triac output and neutral line) but the calculated values showing as Vr+Vc+Vled = 1.3+219+18 = 238.3V.
    Where i am wrong?
  6. #6
    Full Member level 3
    Points: 2,428, Level: 11
    Achievements:
    7 years registered
    Join Date
    Nov 2009
    Pakistan
    Posts
    183
    Points
    2,428
    Level
    11
    see the current rating, u may have exceeded the current rating of LED
    •   Alt21st June 2013, 10:37
      advertising
  7. #7
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,508
    Points
    70,369
    Level
    64
    It's nothing to do with the current rating. The reason you are measuring the voltage is the LED is conducting as a diode in one direction and breaking under the strain in the other. The asymetric result is the strange DC you see. LEDs must be run from a DC supply but you are using AC, on one half cycle of the mains it conducts and if not already killed, it lights up as expected. On the other half cycle the LED supply is reversed which means it does not conduct current until it reaches a voltage that causes it to break down. The 18V you measure is actually in reverse polarity to the voltage that lights it up. If you check the data sheet for most LEDs they are only rated to withstand about 5V in the reverse direction, you are trying to give yours 230V (about 320 at peaks). If you wrap a bridge rectifier around it like I suggested it will conduct on both polarities and not only light brighter but be a LOT more reliable!
    Brian.
    1 members found this post helpful.
