+ Post New Thread
Results 1 to 15 of 15
  1. #1
    Advanced Member level 3
    Points: 4,258, Level: 15
    rajaram04's Avatar
    Join Date
    Jun 2012
    earth
    Posts
    856
    Points
    4,258
    Level
    15
    L.E.D forward current measurment
    Hello sir
    If incase we don't have any idea about the forward current ratings for an L.E.D while purchasing or getting it from somebody then how to calculate the maximum required forward current rating ???
    •   Alt3rd June 2013, 21:44
      advertising
  2. #2
    Advanced Member level 5
    Points: 33,525, Level: 44
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    tpetar's Avatar
    Join Date
    Sep 2010
    Pancevo-Belgrade, Serbia
    Posts
    6,427
    Points
    33,525
    Level
    44
    Re: L.E.D forward current measurment
    I dont know my friend, I see you stuck with these LEDs. :smile:
    Sometimes is easier to buy new from catalog with known manufacturer, model ID and good datasheet then to experiment and destroy LEDs on test.
    LEDs what you show in previous thread 3mm 5mm or 8mm THT LEDs usually have current ratings 25mA 35mA, not more. Monitor heating of LEDs body and legs on short and long time.
    If LEDs are white, supply 3,4V to LED and measure current.
    “Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.” Nikola Tesla
  3. #3
    rajaram04's Avatar
    Join Date
    Jun 2012
    earth
    Posts
    856
    Points
    4,258
    Level
    15
    Quote Originally Posted by tpetar View Post
    hmm seems no other idea we can apply to get results easily . . ok as you say
    Well as you told about 3.4 volts earlier so may i apply 3.6 v inplace of it ? or i ll hv to make 3.4 v exactly ???????
  4. #4
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    You skip first step in electronics to get or make as first project nice small lab power supply. :smile:
    If you dont have it, use 6V or 12V battery and voltage regulator LM317 or similar and adjust voltage to your needs.
    For short you can try Li-Po or Li-Ion battery which is half empty and shows 3,4V - 3,6V. Even small battery from phone can help you.
    •   Alt3rd June 2013, 22:24
      advertising
  5. #5
    rajaram04's Avatar
    Join Date
    Jun 2012
    earth
    Posts
    856
    Points
    4,258
    Level
    15
    okk what about it ???
    Click image for larger version.
    i ve this one as a compact hand held
  6. #6
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    You can try, but for testing current you need more current reserve. This small tiny battery maybe is old and weak to supply needed current and this can give wrong reading in your test.
  7. #7
    rajaram04's Avatar
    Join Date
    Jun 2012
    earth
    Posts
    856
    Points
    4,258
    Level
    15
    okk sure
    so for LM 317 i GOT R1 as 150 ohms & R2 as 258 ohms from the oline calculator
    to get this required 3.4 volts as you said
    so here is the diagram
    so is it ok or any changes we need here ?
    •   Alt3rd June 2013, 22:41
      advertising
  8. #8
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    Better use potentiometer that you can adjust various voltage.
    Easy Adjustable Supply
    http://www.ladyada.net/library/equipt/diypsupp.html
  9. #9
    rajaram04's Avatar
    Join Date
    Jun 2012
    earth
    Posts
    856
    Points
    4,258
    Level
    15
    hmm ohh okk
    thats a preety cool circuit for me
    now let see then how much i can proceed to get all results . . well thanks
  10. #10
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    Input voltage can be higher then 9V, such as 15V-20V.
    If you use transformer with Graetz bridge use higher capacitor values, plus on output add 100nF.
  11. #11
    rajaram04's Avatar
    Join Date
    Jun 2012
    earth
    Posts
    856
    Points
    4,258
    Level
    15
    If you use transformer with Graetz use higher capacitor values, plus on output add 100nF.
    okk sure i ll take care of it
    well sir a 9 volts battery is shown here so is it a rechargable high current rating one or simple one ??
    is it possible to drive LM 317 with normal batteries ?
  12. #12
    Points: 20,015, Level: 34
    Achievements:
    7 years registered
    pranam77's Avatar
    Join Date
    Apr 2008
    INDIA
    Posts
    2,777
    Points
    20,015
    Level
    34
    As LED's are current sensitive devices, testing them with a direct variable power supply or 3.6 volt battery is never recomended. Try searching a constant current source to test led's. Connecting the X led to the tester and measuring the voltage across will give you the 99% perfect forward voltage of a unknown LED. make a small handly circuit shown below to test almost any through hole LED's
    •   Alt5th June 2013, 15:01
      advertising
  13. #13
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    Quote Originally Posted by rajaram04 View Post
    Can be alkaline or standard, no problem.
  14. #14
    rajaram04's Avatar
    Join Date
    Jun 2012
    earth
    Posts
    856
    Points
    4,258
    Level
    15
    Quote Originally Posted by pranam77 View Post
    ohhhhhh i see gr8 work yaar :smile:
    nice nice ok i ll proceed as per the diagram
    so here X LED means ?
    can we connect 5 LEDs parallely at a time as per figure ??????????
  15. #15
    rajaram04's Avatar
    Join Date
    Jun 2012
    earth
    Posts
    856
    Points
    4,258
    Level
    15
    this circuit is much better option thanks
    do you have any kind of it for current measurement ???
    please have me a diagram
